Latest post Fri, Dec 26 2008 8:24 PM by sverkalo. 12 replies.
Page 1 of 1 (13 items)
  • Tue, Dec 23 2008 12:40 AM
    • DC66STEPS
    • Los Angeles
    • Posts 88
    • Points 1,170
    Vista Business 64-bit: now have sluggish and garbage graphics
    I recently rebuilt my workstation to run a clean install of Vista Business 64-Bit. I'm referring to Workstation #1 on my profile details. I haven't even installed Media Composer yet and I'm running into some problems.
    The graphics appear sluggish when redrawing windows, etc. The problem is amplified when I go into "Aero" mode; I get garbage graphics appearing all over. I have the 64-bit version of the graphics driver installed.
    I've checked every setting I could think of but cannot seem to solve this problem. Any ideas?
    WORKSTATION 1: Avid Media Composer v4.0.2 --- Windows 7 Ultimate (64-BIT) --- QuickTime Pro --- Tyan i7525 (S2676) with dual 3.6Ghz Xeons --- 8GB (ECC... [view my complete system specs]
    D~C
  • Tue, Dec 23 2008 2:18 AM In reply to
    • tshirk
    • Joined on Mon, Dec 22 2008
    • Posts 5
    • Points 65
    Re: Vista Business 64-bit: now have sluggish and garbage graphics
    Did you try putting the graphics card in another slot?  I had a similar problem and it was a bad connector on one of the expansion slots.
  • Wed, Dec 24 2008 9:37 PM In reply to
    • DC66STEPS
    • Los Angeles
    • Posts 88
    • Points 1,170
    It is for a PCI-Express slot and I only have one of them. Plus, it worked fine on the same mobo with XP installed. This problem began right after a clean install of Vista Business 64-bit.
    D~C
  • Thu, Dec 25 2008 12:54 PM In reply to
    • sverkalo
    • Thessaloniki Greece
    • Posts 4,787
    • Points 57,000
    I am planning on buying Vista Business 64 bit to go in with my MC upgrade.
    I will follow this thread.
    Desktop
    Armor 8000/Zalman 600W/Abit IP35Pro/Quad 6600@3G/8G Corsair DDR2 800/Geforce 8800GTS 640@Quadro FX 5600(169.47)/X-Fi Xtreme Music/160WD S2/2x1TB Samsung F1(RAID 0)/Many e-SATA drives/Samsung 203B/Vista Business SP1 64bit/Avid Media Composer 3.1.3 Suite/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    Laptop
    Fujitsu Siemens(Amilo Xi 2528-07)/T8100/3G DDR2/8600M GS 256/Realtek HD/Many e-SATA drives/Optiarc 7540/Optiarc 7240S(USB)/Vista Business SP1 32bit/Avid Media Composer 3.1.3 Suite.
    My Films
  • Thu, Dec 25 2008 1:51 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 3,107
    • Points 35,505
    Maybe it would be better to do the test with Avid than with Vista Aero, aero shouldn´t be used on any editing sys I think, all the bells and whistles should be turned off, much better to use the copmputer power for editing than to have a fancy screen look.
    MC 4,03 ( Liquid 7,2 ) V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 8 GB, PNY Quadro 1800, Soundblaster X-Fi... [view my complete system specs]
    Tomas
  • Thu, Dec 25 2008 2:14 PM In reply to
    • sverkalo
    • Posts 4,787
    • Points 57,000
    I think this is why Business is almost like Ultimate but with games and media center cut off.
    And that's why Avid chose this one for MC.
    Desktop
    Laptop
    My Films
  • Thu, Dec 25 2008 2:34 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,107
    • Points 35,505
    sverkalo:
    Well, maybe you should do your installation first George ...
    Tomas
  • Thu, Dec 25 2008 10:03 PM In reply to
    • DC66STEPS
    • Los Angeles
    • Posts 88
    • Points 1,170
    mjolnarn:
    I totally agree. But this is all happening BEFORE Avid is even installed. I've switched between Vista Basic and Aero just to test. The trouble I'm having is just with normal desktop behavior. I haven't even begun to tinker with Avid under these conditions (and I don't plan to until I can sort this out first).
    D~C
  • Thu, Dec 25 2008 10:28 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,107
    • Points 35,505
    as you are using the os for your hardware test, what is your experience index ?
    Tomas
  • Fri, Dec 26 2008 6:53 PM In reply to
    • DC66STEPS
    • Los Angeles
    • Posts 88
    • Points 1,170
    mjolnarn:
    Yes, my experience index was 4.3, I think.
    I tried reinstalling the graphics card driver with no luck.
    One thought I have is that maybe the graphics card is not properly seated or needs the pins/slot to be cleaned?
    The other thought I have is a faulty installation of Vista causing this. Come to think of it, I did have a problem during the initial installation. At one point, the screen said something about Vista testing the hardware so the software could adjust to the best settings. The test began and early during the progress, it seemed to freeze. I waited about 2 hours and nothing changed. So I powered off and re-booted. Vista seemed to start normally for the first time. But I have not been able to get it to display graphics smoothly or properly.
    I'm wondering if there is a way to run that hardware test again and make sure Vista adjusts its settings? Or perhaps I could do some kind of repair re-installation?
    D~C
  • Fri, Dec 26 2008 7:50 PM In reply to
    "... perhaps I could do some kind of repair re-installation ..."
    If it were me, I'd reformat the drive and reinstall Vista from scratch ... unitl it completes normally, with no issues.
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Fri, Dec 26 2008 8:18 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,107
    • Points 35,505
    Randall L Rike:
    one more vote for this procedure, i very often let daddy Bill take care of my probs at first , he is very good at this and it mostly works very well
    Tomas
  • Fri, Dec 26 2008 8:24 PM In reply to
    • sverkalo
    • Posts 4,787
    • Points 57,000
    I think a reformat and reinstall will be the better solution for you as Randall says.
    Tommorrow I will also buy DSP Windows Vista Business 64bit for 145 Euros and I will install it for testing.
    Desktop
    Laptop
    My Films
