Is the Info below still the easiest way to connect my Sony DVW-A500 deck to my AVID-Mojo SDI? Is there a adapter from USB to RS422 that works with Avid so that I don't have to use an RS-232 to RS-422 adapter? If not, which RS-232 to RS-422 adapter do you guys use?
Arnie
From the solutiion database:
The correct adapter to use is the Keyspan 19HS. It can be used with both Mac and PC. It will also work with Media Composer 2.8.x, Symphony 1.8.x, and Newscutter 6.8.x.
Do not use the 28x series Keyspan, it is not frame accurate.
For Mac Leopard use driver version 2.5
For product information check here: http://keyspan.com/products/usa19hs/homepage.spml
http://www.match-cut-mainz.de
arnie....
Yes the 28x isnt suported on the 10.5.x dur to the fact it is not frame accurate.
The below is the latest info I could find but the best bet is to conact sales tomorrow or ping me via email and I can check directly for you. They are sleeping now....
7070-00507-01 CBL,PC DECK CONTROL CONV RS232-RS422.
813-493-6800 mobile
AOL IM avidmarianna
When did the 28x stop being frame accurate- Osx 10.5 or earlier?
St.John
Bump
We are in the process of upgrading to a new CPU running OS 10.5 and MC 3.5. I came across documentation that we need the USA-19HS so I bought one and the computer and Avid deck config. saw it but, the decks would not work. Now I see this additional note about an adapter? Where can I buy this adapter? I didn't see one on Tripplite's site and they don't sell them anyway, you have to go to another supplier?
Thanks!!!
Nancy
Is this what we need? http://www.rs232-converters.com/RS232_to_RS422_Converters/RS232_to_RS422_Converter.htm
Is this the "standard converter that I need?
