Latest post Fri, Sep 11 2009 3:39 PM by Ace Editor. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Dec 19 2008 12:25 AM
    • arnie
    • Posts 22
    • Points 275
    KEYSPAN PROBLEM
    Is the Info below still the easiest way to connect my Sony DVW-A500 deck to my AVID-Mojo SDI? Is there a adapter from USB to RS422 that works with Avid so that I don't have to use an RS-232 to RS-422 adapter? If not, which RS-232 to RS-422 adapter do you guys use?
    Arnie
    From the solutiion database:
    The correct adapter to use is the Keyspan 19HS. It can be used with both Mac and PC. It will also work with Media Composer 2.8.x, Symphony 1.8.x, and Newscutter 6.8.x.
    Do not use the 28x series Keyspan, it is not frame accurate.
    • For the PC use driver version 3.7s
    • For Mac Leopard use driver version 2.5
    • An RS-232 to RS-422 serial adapter is required
    For product information check here: http://keyspan.com/products/usa19hs/homepage.spml
    http://www.match-cut-mainz.de
  • Fri, Dec 19 2008 2:17 AM In reply to
    • Posts 1,595
    • Points 19,885
      Avid Employee
      Moderator: Broadcast Newsroom
    Re: KEYSPAN PROBLEM
    arnie....
    Yes the 28x isnt suported on the 10.5.x dur to the fact it is not frame accurate.
    The below is the latest info I could find but the best bet is to conact sales tomorrow or ping me via email and I can check directly for you.  They are sleeping now....
    7070-00507-01 CBL,PC DECK CONTROL CONV RS232-RS422.
    Customer Advocate/Customer Success [view my complete system specs]
    813-493-6800 mobile
    AOL IM avidmarianna
  • Mon, Dec 22 2008 1:02 PM In reply to
    • St.John
    • UK
    • Posts 159
    • Points 1,920
    Re: KEYSPAN PROBLEM
    When did the 28x stop being frame accurate- Osx 10.5 or earlier?
    St.John
    Mac pro 2.66 GHz 2gb ram OSX 10.4.11 qt 7.4.5, MC 3.05,mojo gtech drives firewire 800 connection Mac pro 2.8 6gb ram, OSx 10.5.5 QT 7.5.5, MC 3.05 Nitris... [view my complete system specs]
  • Tue, Dec 30 2008 5:59 PM In reply to
    • St.John
    • UK
    • Posts 159
    • Points 1,920
    Re: KEYSPAN PROBLEM
    Bump
  • Thu, Sep 10 2009 9:37 PM In reply to
    • Ace Editor
    • Joined on Fri, Jan 4 2008
    • Jupiter Productions
    • Posts 23
    • Points 240
    Re: KEYSPAN PROBLEM
    We are in the process of upgrading to a new CPU running OS 10.5 and MC 3.5.  I came across documentation that we need the USA-19HS so I bought one and the computer and Avid deck config. saw it but, the decks would not work.  Now I see this additional note about an adapter?  Where can I buy this adapter?  I didn't see one on Tripplite's site and they don't sell them anyway, you have to go to another supplier?
    Thanks!!!
    Nancy
    Is this what we need? http://www.rs232-converters.com/RS232_to_RS422_Converters/RS232_to_RS422_Converter.htm
    MacBook Pro, 2.33 Ghz, Core 2 Duo and G5, Power PC, 2.7 dual with AdrenalineHD both running Media Composer 2.7.2 [view my complete system specs]
  • Fri, Sep 11 2009 8:26 AM In reply to
    • mvegas
    • Posts 1,436
    • Points 16,450
    Re: KEYSPAN PROBLEM
    Model #: USA-19HS
    from Keyspan.com.  USB to RS 232 converter.  You can then use a standard rosetta stone to convert to RS 422.
  • Fri, Sep 11 2009 3:39 PM In reply to
    • Ace Editor
    • Posts 23
    • Points 240
    Re: KEYSPAN PROBLEM
    Is this the "standard converter that I need?
    Nancy
