Latest post Thu, Dec 18 2008 11:49 AM by Baklap. 2 replies.
  • Wed, Dec 17 2008 2:26 PM
    Backing up omfi files to DVD
    Hi Id like to know how to identify the omfi mediafiles on the hard drive from amongst loads of others, and copy these so i can back them up to a dvd. and once ive done this, and then re put them back in the folder in the futiure from the dvd backup, will the sequence see those files correctly. Any steers appreciated. Peter
  • Wed, Dec 17 2008 5:22 PM In reply to
    • HoolioEdits
    • Joined on Mon, Nov 10 2008
    • Toronto
    • Posts 9
    • Points 140
    Re: Backing up omfi files to DVD
    A Quick way would be to use media tool and consolidate the media to another drive if you have one, then burn those files to DVD.  You can identify the consolidated media by the modification date of the file.
    Media Composer 3.0 Mac OSX Leopard 10.5.5 Dual 2.8 GHz Quad-Core Intel Xeon Processors 2GB Ram [view my complete system specs]
    Hoolio Edits
    hoolioedits@gmail.com
    http://hoolioedits.blogspot.com
  • Thu, Dec 18 2008 11:49 AM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,825
    • Points 80,630
    If it is only the sequence you want then consolidating is an option...
    Add an empty removable drive to the sys, consolidate the sequence to that drive. Once done you will have a omfi media files folder there. You can rename that folder to the project name for future reference. Once renamed you can consolidate another project which will create a new omfi media files folder.. rename as well etc etc..
    Be sure to keep a copy of the project and do not rely on extern discs for 100% they break,, quite fast :)
    Hope this can be a way. there are at least 5 other ways to do this but they all require a much longer reply ;)
    Menno
    MC 3.5.1 Test-Intel Core2Duo 6800,GTS8800 Nvidia,Realtek HD, 21" Samsung display [view my complete system specs]
    Dutch AV forum
