Latest post Thu, Dec 18 2008 1:43 AM by Hedeen. 4 replies.
  • Tue, Dec 16 2008 1:54 PM
    • 42MPGuy
    • Joined on Tue, Dec 16 2008
    • Posts 2
    • Points 30
    Video Format Issue
    I'm tryig to capture video from 2 HDV cameras with diffierent Video formats. I initially captured in 1080i from my Canon XH A1 which captured fine. I then attempted to capture from my JVC GY-HD110U. When I added the JVC as a new Deck it only gave me the option to connect as a HD100. Once I did that the formats offered was DVCPRO and 1080i. If I select DVCPRO, I get a message indicating no input signal. If I select 1080i, I get an error indicating that there was a format mismatch 720/1080.
    My guess is that the project is set at 1080i and the camera is capturing at 720p. My question is am i going to be able to mix shots from these 2 camera's and how? I'm using Media Composer 3.0 and capturing through firewire.
  • Tue, Dec 16 2008 2:20 PM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Posts 261
    • Points 2,950
    Re: Video Format Issue
    Well you can change the project type, capture the 720 material and then transcode one or the other to match. Which is best to run with will depend on the material and the look you want.
    2x MC 2.6.6 with Mojo on HP xw8400 MC Adrenaline 2.6.6 on HP xw8400 MC 2.8 on MacPro dual 2.66 Editshare 4.1 [view my complete system specs]
  • Tue, Dec 16 2008 2:22 PM In reply to
    • sverkalo
    • Thessaloniki Greece
    • Posts 4,787
    • Points 57,000
    Why to transcode?
    MC has an open timeline.
    When you want to capture to a new format just change the project type at format options.
    Desktop
    Armor 8000/Zalman 600W/Abit IP35Pro/Quad 6600@3G/8G Corsair DDR2 800/Geforce 8800GTS 640@Quadro FX 5600(169.47)/X-Fi Xtreme Music/160WD S2/2x1TB Samsung F1(RAID 0)/Many e-SATA drives/Samsung 203B/Vista Business SP1 64bit/Avid Media Composer 3.1.3 Suite/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    Laptop
    Fujitsu Siemens(Amilo Xi 2528-07)/T8100/3G DDR2/8600M GS 256/Realtek HD/Many e-SATA drives/Optiarc 7540/Optiarc 7240S(USB)/Vista Business SP1 32bit/Avid Media Composer 3.1.3 Suite.
    My Films
  • Wed, Dec 17 2008 2:46 PM In reply to
    • 42MPGuy
    • Posts 2
    • Points 30
    Thanks, that worked... I think I am going to exchange my JVC for another Canon 1080i though.
  • Thu, Dec 18 2008 1:43 AM In reply to
    • Hedeen
    • Joined on Mon, Dec 15 2008
    • Atlanta GA
    • Posts 38
    • Points 510
    yes,,, open another project. ingest into that project...and import over into yr bin. let AVID do the work.
    running 3 avids. 3.0 on a PC desktop. 3 GB ram 3.00 ghz. same on a PC laptop.(2.2 gb 2.4 ghz) got a Nvidia 1400 card in the PC... running 3.0 on macbook... [view my complete system specs]
    "Surprise! It's AVID!"
