Latest post Fri, Dec 12 2008 9:58 PM by GeorgeD. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Dec 11 2008 10:51 PM
    • swest26
    • St. Louis
    • Posts 67
    • Points 860
    Raid 5 Options
    Anyone using non avid raid 5's.  Here's one on Ebay (if the link doesn't work search for Item 310102732536)
    Is a port multiplier totally out of the question?  In real situations- not just in theory.
    I edit mostly from p2 source or XDCAM- so either DV or DVCPRO 50 or 100 or XDCAM.
    I have a MOJO(standard), but may be upgrading to MOJO DX or a used Adreniline HD.
    I have routinly used USB drives on an Adreneline for XDCam HD without any problems.
    3 Systems HP 8200 Nvidia FX3450 Dual 3.7's 4 Gig Ram HPZ8000 Laptop 3.4 1 gig ram Mac G5 Dual 2.8's OS 10 4 gig ram Avid Media Composer 2.8.4 with... [view my complete system specs]
  • Thu, Dec 11 2008 11:06 PM In reply to
    Re: Raid 5 Options
    At home I'm using 2 x SansDigital 4-drive 1RU chassis' with a 3-Ware 9690SA-8E controller.  So far, works great.  Each chassis has 4 x 1TB Seagate drives, in a separate RAID-5 array.  Each nets 2.75TB's
    http://www.sansdigital.com/elitestor/es104ti.html
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Fri, Dec 12 2008 9:43 AM In reply to
    • andro
    • Warsaw
    • Posts 87
    • Points 1,125
    Re: Raid 5 Options
    I use in all our avid's non avid raid 5 but very imortan for it is good contoler card(with ram on it and so on) in my case this is ARECA 16port SAS RAID PCIe x8 Controller IOP348-1200, RAID 0/1/3/5/6, 512MB Cache with 12 1GB drive i have about 11GB space and transfer about 600MB/s it rock solid work without any problem month ago one drive broken I only replace it with new one and don't stop work  raid rebuild when system was editing. 12 stream 1:1 now for me not a problem 12 PIP plays like a charm.
    Avid MC 4.0.2 Vista 64 Adrenaline HD HP xw8400, FX 1500, 8GB ram. 2* Avid MC 3.1.2 Vista 64 Mojo SDI HP xw8400, FX 1500, 8GB ram Avid MC 3.0.5 XP... [view my complete system specs]
  • Fri, Dec 12 2008 5:55 PM In reply to
    • GeorgeD
    • Posts 119
    • Points 1,455
    Re: Raid 5 Options
    The ebay item you quoted uses what appears to be a controller card with SIL chipset. The SIL chipset gives you 20MB/s write and 40MB/s  read - not nearly fast enough for editing. The port multiplier itself is not a bottleneck, each port runs at 3Gb/s and can support 4 or 5 drives with minor performance penalty.
    I'm looking at Raid5 boxes that have the controller built into the box, that doesn't require a high performance raid controller in each workstation. For example this one.
    http://www.areca.com.tw/products/esatausb.htm
    http://www.provantage.com/areca-technology-arc-5020~7AREC01P.htm
    Has anybody had experience with these boxes? Rockwell is working a new Raid 5 chip that is supposed to be out soon and should drop the prices again.
  • Fri, Dec 12 2008 9:29 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,385
    • Points 15,850
    Re: Raid 5 Options
    I've found this on the Mac forum a while ago, don't remember the exact thread but if You find it to be interesting may be worth running a search over there.
    MC 3.5/Mojo, Vista 64 biz, Gigabyte GA-EP45T-EXTREME, Intel Q9450, 8 GB ram, Pyro 64, Quadro FX 1700, 2 x 1TB drives (raid 0) for mediafiles + G4 MacBook... [view my complete system specs]
    peace luca
  • Fri, Dec 12 2008 9:58 PM In reply to
    • GeorgeD
    • Posts 119
    • Points 1,455
    Re: Raid 5 Options
    The Firmtek enclosure looks great but I believe at that price it should inlcude a Raid 5 controller in the box. Hopefully we will see Raid5 boxes that include the controller soon. Compare to Areca 5020.
