Latest post Fri, Dec 5 2008 3:03 AM by mr_difficult. 3 replies.
  • Fri, Dec 5 2008 2:04 AM
    • jennnnnnn
    • Joined on Tue, Nov 25 2008
    • Posts 8
    • Points 150
    Timewarp Effect
    When using the Timewarp Effect, is there a way to tell set an OUTpoint for the effect, so that if you change the speed of the clip from 100% to 1000% the clip ends where it originally ended, and you are not forced to re-establish your outpoint on the timeline?
  • Fri, Dec 5 2008 2:09 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,170
      Moderator: Meridien
    Re: Timewarp Effect
    J:
    Activate both the speed graph and the position graph in the timewarp tool. Now adjust the two sliders on the position graph so that you can see all boundaries of the box. The top and bottom boundaries represent the duration of the effect with the left and right sides representing the length of the timeline clip. Make sure the diagonal line exits precisely on the top right corner point. Adjust you speed graph accordingly.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Fri, Dec 5 2008 2:53 AM In reply to
    • jennnnnnn
    • Posts 8
    • Points 150
    Re: Timewarp Effect
    Awesome!  I'll try this.
    Thanks so much Geeked
  • Fri, Dec 5 2008 3:03 AM In reply to
    Re: Timewarp Effect
    Apply the timewarp to the clip. Open the timewarp editor. Click on the last keyframe. Hit the "Anchor" button. The last keyframe is now the anchor point.  Adjust speed the way you want. The last frame will always be the last frame.
    MC 2.5.1 with Analog Mojo. HP xw8000, dual 3.0 Xeon, 3 Gig Ram, nVidia FX1100, ADS Pyro Firewire Card. [view my complete system specs]
