Latest post Sat, Nov 22 2008 8:17 PM by Larry Rubin. 8 replies.
Page 1 of 1 (9 items)
  • Sat, Nov 22 2008 2:38 PM
    • ssthilaire
    • Joined on Thu, Nov 13 2008
    • Posts 8
    • Points 110
    How do I seperate my video from audio?
    I am new to this...
    I tried to export the video from a mixed clip in Avid Free DV by clicking "Export", then selecting "Video Only" in the options... But when I go ahead with the export up pops an error box "errcode; 8961".
    Help?!
  • Sat, Nov 22 2008 3:22 PM In reply to
    • camoscato
    • Posts 6,068
    • Points 72,830
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: How do I seperate my video from audio?
    We need to know a few things in order to help.  First, what are your system specifications (processor type & speed, amount of RAM, video card, what version of Quicktime is installed on the system), and second, what are you trying to achieve?  Are you exporting for the web or DVD or something else?
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Sat, Nov 22 2008 3:43 PM In reply to
    • ssthilaire
    • Posts 8
    • Points 110
    My OP system is Windows Vista 32-bit, AMD Athlon(tm) 64 Processor 4000+ 2.60GHz, RAM 767 MB.
    I believe I have Quicktime 6.1? installed. I would like to add in my own music to my editing. So what I was trying to do was just seperate my mixed video so that I could import my own audio. So i tried to export video only, but then the errcode 8961 popped up.
    Thanks for your response.
  • Sat, Nov 22 2008 5:10 PM In reply to
    • tompearson
    • Joined on Thu, Mar 1 2007
    • Wayzata MN
    • Posts 576
    • Points 6,210
    i would try to delete the sound on the tracks and add my own rather than  export a video trk  or you could do a video mix down and open a new sequence and add the mixdown video trk and your music mix
    asus mb p5wd2 dualcore 3 gig intel cpu's 4 gig crucial ram nvidia quadro fx 3500 1 tb wd sata 7200 raid 0 seagate 160 gig sata 7200 os drive mojo command... [view my complete system specs]
    Tom Pearson Director Hollywood-sounds.com
  • Sat, Nov 22 2008 5:28 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,992
    • Points 107,005
      Moderator: Meridien
    I'm sorry, but Free DV, which is now an "end of life" product, was never qualified to run on Vista in any flavor.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Sat, Nov 22 2008 7:41 PM In reply to
    • ssthilaire
    • Posts 8
    • Points 110
    ya I changed the compatibility to Windows 98 just so i could install avid...
    How do I delete the audio?
  • Sat, Nov 22 2008 8:05 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,992
    • Points 107,005
      Moderator: Meridien
    Mount your sequence, activate all audio tracks present, mark in at the beginning of the sequence and mark out at the end, then delete.
  • Sat, Nov 22 2008 8:13 PM In reply to
    • ssthilaire
    • Posts 8
    • Points 110
  • Sat, Nov 22 2008 8:17 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,992
    • Points 107,005
      Moderator: Meridien
    You're welcome. Keep in mind if DV Free has the "Avid Attic" folder, and you needed your audio timeline back, you could find it there in a version of the sequence made before the point in time (today) when it was deleted.
    Or alternately, make a clone of the sequence before you delete the audio.
