every time I launch MC, I get this error message. You system caledar and clock need to be set to the current date and time or problems may result? I put a new battery in and still have this problem.
I set the date and time correct and still have this problem.
What did I not do???????????????
What version of Media Composer?
Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
The version I am using is MC V7.2 ON A POWER MAC 9600
thanks for your reply........
I also got that error when I was using that set up. It's probably a software bug. They may not have expected people to be still using that system in 2008. I think you can just ignore the message
Hoolio Edits
hoolioedits@gmail.com
http://hoolioedits.blogspot.com
Thanks for the reply. I too use the older software and it still works fine.. Keep in touch maybe I could help you one-day.....
That's what I thought. There's a timeout in the Avid code that kicked in on Jan 1, 2006 I believe. Essentially the code is only dated to that point. The issue is in the Avid code, not your computer. You only have two options to defeat this issue. One is to change the date and time to a fake time to "trick" the Avid software into thinking it's pre-2006. Or you can just click past the error message each time you boot and ignore it. It in fact will have 0 impact on your editing. I too have an ABVB suite in the back room and just click past it. No problems.
Thank You I will take the second option and by-pass it. You too seem to have a-lot of knowledge on the older avid system, that still works great.
