Latest post Wed, Dec 10 2008 10:27 PM by BLKDOG. 17 replies.
  • Sat, Nov 15 2008 9:12 PM
    • freelance
    • Joined on Wed, Sep 20 2006
    • Posts 54
    • Points 760
    16:9 sequence ends up as a 4:3 sequence when I export it. Why?
    I have a sequens in 16:9 that I want to export. but when I try to export it as a quick time movie it end up as a 4:3 sequens.
    I have also tried to do a digital cut but it becomes 4:3 on the tape as well.
    Whats wrong? What do I miss?
    Facts about my computer: Dell Dimension 9150 PD 920 processor Dual core (2,80GHz, 800FSB, 2*2MB 2048 MB Dual Channel DDR2 533MHz (2*1024) Memory 320GB... [view my complete system specs]
    freelance
  • Sat, Nov 15 2008 9:23 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,992
    • Points 107,015
      Moderator: Meridien
    Re: 16:9 sequens end up as a 4:3 sequens when I export it. Why?
    What is the format of the project? I would assume it's 30i. Suggest you change the project format to an HD format and try again.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Sat, Nov 15 2008 9:48 PM In reply to
    • HoolioEdits
    • Joined on Mon, Nov 10 2008
    • Toronto
    • Posts 9
    • Points 140
    Assuming that the sequence is anamorphic, you need to apply the 16:9 reformat effect before you export.  This will letterbox the clip.  OR, If it's for quicktime you could also adjust the dimensions to something that is in the 16:9 aspect ratio
    Media Composer 3.0 Mac OSX Leopard 10.5.5 Dual 2.8 GHz Quad-Core Intel Xeon Processors 2GB Ram [view my complete system specs]
    Hoolio Edits
    hoolioedits@gmail.com
    http://hoolioedits.blogspot.com
  • Sun, Nov 16 2008 12:25 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 4,234
    • Points 48,665
    If you're exporting for DVD don't whatever you do reformat.  Instead export as-is and tell your encoding software that the media is 16:9.  That way it will play back at fullscreen and full resolution on a 16:9 monitor, and letterboxed 16:9 on a 4:3 monitor.
    MC 4.0.3 - Asus P6T Deluxe V2 mobo - Intel i7 920 2.66GHz - nVidia Quadro 1700 - 12 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro firewire... [view my complete system specs]
  • Sun, Nov 16 2008 12:29 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,992
    • Points 107,015
      Moderator: Meridien
    jwrl:
    Good advice. If applicable, follow it.
  • Sun, Nov 16 2008 8:24 PM In reply to
    • freelance
    • Posts 54
    • Points 760
    At first the footage was in DVC PRO HD.
    But since I wanted to do a digital cut as a SD format, I modified the sequens to 25i PAL and changed the project format to 25i PAL. Then I did a videomixdown to change the resolution to DV 25 420. I tried to export the sequens as a quicktime movie and the result came out in 4:3.
    If I try with a export as quicktime again, how do I adjust the dimensions to something that is in the 16:9 aspect ratio?
    I am from Europe, so I use 25i instead of 30i.
    freelance
  • Sun, Nov 16 2008 8:51 PM In reply to
    In the export dialogue box, there's a setting that determines the aspect ratio of the resulting QT file (Display Aspect Ratio). It is at the bottom right of the dialogue box. You can choose to set it to native (720x576) or 4x3 (768x576) or 16x9 (1024x768). Set it to 16x9.
    Manual says:
    The display aspect ratio allows you to apply a scaling to the video: Native, 4:3, or 16:9. The display aspect ratio lets you control the display format without modifying the source file.
    This feature creates metadata - additional data that is stored with the QuickTime movie. Some applications, such as the QuickTime Player, can interpret this metadata and scale the image at display time.
    Display aspect ratio is useful for the Same as Source option because that option also preserves the original format. When you select Same as Source, the selections in the Display Aspect Ratio area are based on the resolution of the media you are exporting and the project type (NTSC or PAL).
    When you select Custom, your Avid editing application calculates the Display Aspect Ratio selections on the values you enter for Width x Height in the Video Format tab.
    The Avid does not support the (non-standard) widescreen flag for output to tape. All 16x9 PAL SD lives in the 720x576 environment. It's merely a question of display aspect ratio.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Tue, Dec 9 2008 9:32 PM In reply to
    • freelance
    • Posts 54
    • Points 760
    HoolioEdits:
    If I want to do a digital cut, is there a " 16:9 reformat effect"? Where do I find it? In the effects editing toolset?
    freelance
  • Tue, Dec 9 2008 9:34 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,822
    • Points 201,035
    It's in the Effect pallet under "Reformat"
  • Wed, Dec 10 2008 7:18 PM In reply to
    • freelance
    • Posts 54
    • Points 760
    Is the 16:9 reformat effect the best way when I want to do a digitalcut? The original footage is in 16:9.
    freelance
  • Wed, Dec 10 2008 7:26 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,822
    • Points 201,035
    If you are digital cutting in SD, yes. Remember, if you are playing out HD (or 16 x 9 SD for that matter) in SD, the 16 x 9 footage is actually 4 x 3 Anamorphic and will need a reformat effect to make it 16 x 9 letterbox.
  • Wed, Dec 10 2008 7:50 PM In reply to
    • freelance
    • Posts 54
    • Points 760
    The original footage is in 16:9 HD. But I would like to do a digital cut to SD. So then its ok with the 16:9 reformat effects, right?
    freelance
  • Wed, Dec 10 2008 7:54 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,822
    • Points 201,035
    Sure, just change your project's format to SD using the format tab (assuming that you have a compatible project/media type), apply the reformat and output.
  • Wed, Dec 10 2008 9:35 PM In reply to
    • freelance
    • Posts 54
    • Points 760
    Do I have to use the 16:9 reformat effect when I want to export a sequens as well?
    freelance
  • Wed, Dec 10 2008 9:42 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,822
    • Points 201,035
    It depends on what format you want the sequence to be when you encode. If you want it to be 16 x 9 (No letterbox) then export directly from the HD project format. If you want an SD 16 x 9 letterbox, then just export the sequence from the SD project format with the reformat effect.
