Latest post Sun, Nov 16 2008 3:36 AM by catwoman. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Nov 4 2008 5:20 AM
    Clipbrowser putting Main Conept logo in all exported video
    Using new EX1 and when I export from Clipbrowser, I get a "Main Conect" watermarked logo in the upper left of all video clips.  Any idea how to rid of this?
    Dell Precision M90 laptop, Quadro FX2500M, Windows XP SP2, MC 2.8.4 [view my complete system specs]
  • Tue, Nov 4 2008 9:03 AM In reply to
    • PPavel
    • Joined on Fri, Jun 9 2006
    • Brno, Czech Republic
    • Posts 117
    • Points 1,335
    Re: Clipbrowser putting Main Conept logo in all exported video
    ClipBrowser should only rewrap the MPEG2. That's strange. Which kind of conversion you did? MP4 -> MXF? You have to choose Export to NLEs for conversion to Avid or Export to Avid AAF. Which version of ClipBrowser do you use?
    PP
    MC 3.0.5, Mojo, Dell 670, 2x Xeon 3.2GHz, 2GB RAM, nVidia Quadro FX4000, Win XP SP2 [view my complete system specs]
    Filed under: ,
  • Tue, Nov 4 2008 3:34 PM In reply to
    Thanks PP,
    I am using Clipbrowser 2 and I am exporting to MXF XDCAM HD and it puts the logo on all the video.  When I export MXF NLE it does not put the logo.  Thanks.
    I am fairly new to AVID and am confused when I try to export to AAF, then import to AVID, the master clips in AVID state they are offline.  Why is this?
    Is there a benefit to using MXF or AAF?
  • Tue, Nov 4 2008 3:45 PM In reply to
    • cuervo
    • Joined on Fri, May 2 2008
    • Santa Fe, NM
    • Posts 331
    • Points 4,300
    This is because ClipBrowser 2 provides a watermarked version of transcoders for XDCAM HD files. If you want to get rid of the watermark, you have to buy the MainConcept codec package, which is quite expensive.
    The default codec is "Export for NLE's", as PPavel says. That is the correct conversion to use...ie...mxf.
    Media Composer 4.03 on Win 7 64-bit and XP Pro SP3 - Intel x48, dual core quad 6600 - 8Gb RAM - PNY Quadro FX1700 - Echo Mona [view my complete system specs]
    Chalchihuitl Productions Music video, Digital Imaging JVC HD110--Sony EX1
  • Tue, Nov 4 2008 5:51 PM In reply to
    • PPavel
    • Posts 117
    • Points 1,335
    Why do you want to convert EX footage to XDCAM HD? For backup to XDCAM HD disk? Otherwise you don't need it.
    Using AAF export from Clip Browser would be great if it could retain the clip name and mark In/Out which you've created in it. But it doesn't. (XDCAM tool for Mac is 100x better.)
    You can use the ClipBrowser for choosing and deleting clips only. Then perform Export to MXF for NLEs. ClipBrowser only rewraps the stream from MP4 to MXF container. Place those files into Avid MediaFiles\MXF\2 (or create other numbered folder like Avid MediaFiles\MXF\456687). If you decide to put MXF into folder which already has files in it you MUST delete the msmFMID.pmr and msmMMOB.mdb files in that directory in order to make Avid to rescan those folders.
    After placing MXF files into proper folders start Avid. (It is not necessary to close the Avid during manipulations with files.) Open Media Tool and find your newly added clips. The Creation Date column will help you locate your clips. The Creation Date matches to date and time at which you've created MXFs in Clip Browser. Select those clips In Media Tool window and drag them into bin (or bins). Now you can start with editing.
    You'll notice a slower response when you drag the playhead across the source monitor and timeline. It's because the long GOP nature of video data. If you find it annoying, you can switch the project into SD and transcode your footage into DV (for example) and relink it back for output (or during color correcting and composing). If you plan to transcode your footage it's safer add to clips the name of tape first, as Avid uses this name for relinking media files.
    If you've never done it before, always do tests.
    PP
    Filed under: ,
  • Wed, Nov 5 2008 1:57 AM In reply to
    Thanks for all the help.  I am a newbie now, but hopefully in time I can return the favor by helping others.
  • Wed, Nov 5 2008 3:08 PM In reply to
    • cuervo
    • Santa Fe, NM
    • Posts 331
    • Points 4,300
    There's a number of ways to import mxf clips re-wrapped by the Sony ClipBrowser. I prefer this method:
    1-Use CB2 to rewrap native mp4 files to mxf files. Saved location can be anywhere, any directory and folder.
    2-Open avid bin and right click to import. Navigate to the saved mxf and select. Let avid do its thing.
    3-If you like working with long form GOP, you can use the files you just imported into the bin on the timeline.You can't export long form GOP with Quicktime reference movies.
    4-If you want to use Quicktime reference, select the clip and transcode it to the format of your choice. I like to use avid's DNxHD.
  • Wed, Nov 5 2008 4:41 PM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,461
    • Points 39,230
    PPavel:
    [edit] ... cuervo already said that, didn't read whole thread - or transcode to DNxHD to keep the high quality.
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 2x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC 3.5.1, Mojo... [view my complete system specs]
  • Sun, Nov 16 2008 2:50 AM In reply to
    • catwoman
    • Posts 156
    • Points 2,110
    Isn't it faster to export as AAF from the clip browser? Then you don't need to reimport the MXF into Avid. However, when I am trying this, my imported AAF clips show offline. I am going by the Sony manual, but can't figure out why they show offline. Any idea?
    Hardware: Inted Dual Core 3 GHz Asus P5K Mobo 4GB DDR2-SDRAM (1066 MHz) NVIDIA Quadro FX 3500 SIIG firewire card Raptor 40GB SATA (system) Raptor... [view my complete system specs]
  • Sun, Nov 16 2008 3:36 AM In reply to
    • catwoman
    • Posts 156
    • Points 2,110
    Sorry, I just figured it out. I didn't move the MXF files to the "Avid MediaFiles" folder. In conclusion it seems that the fastest way is to export Avid AAF. It does retain the clip name and once done, you just load the AAF master clips into the bin.
