Using a qualified laptop, MC 3.05 will not see Sony DSR70 AP deck, despite Windows recognising the deck. Have checked buffers and deck config variations, but still no joy. If this were a consumer camera hot of the production line I would be more understanding, but this is a piece of Sony broadcast kit that has been around for years. Any suggestions out there????
Hi...
The DSR-70 A deck is supported but not the AP. Not sure why but I know the DSR-70 A is fully compatible.
How are you connected and have you looked at the settings on the deck as my guess is somethign on that side is the culprit.
What kind of tape are you using - or better yet what format?
The DSR-70A template is present in deck configuration. You should manually configure a channel (usually direct on com 1) if analog connections, or Firewire on OHCI if it's connected by firewire and choose the DSR-70A template when adding deck.
