Latest post Fri, Nov 14 2008 7:16 AM by mjolnarn. 17 replies.
  • Fri, Oct 31 2008 5:51 AM
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    From MC direct to AvidDVD (DVDitProHD) or use a 3rd Party Encoder?
     There is an ongoing debate as to whether it is wiser to use a 3rd. party software to prepare files before importing them into  AvidDVD (DVDitProHD) or not.
    I prefer the direct to AvidDVD (DVDitProHD) approach and explain why in this short presentation.
    Regards
    Douglas
    Edit Added: PS. Since making this tutorial it has been pointed out to me (further down in this thread) that you can, of course, use the same "template" in the upper workflow and just replace the video files on the DVDit timelines with either the DVD or Blu-Ray encoded ones without having to re-author.
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Fri, Oct 31 2008 6:01 AM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,461
    • Points 39,230
    Re: From MC direct to AvidDVD (DVDitProHD) or use a 3rd Party Encoder?
     Thanks again Douglas,
    part of the discussion can be explained I think because of the fact that quite a few users don't have AvidDVD and are therefore forced to use third party encoders
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 2x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC 3.5.1, Mojo... [view my complete system specs]
  • Fri, Oct 31 2008 6:32 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    jknikman:
     Good point, Hans
    I hadn't considered that!
    I was referring more to those who actually have AvidDVD or DVDitPro HD and are advocating what I guess you might call a 4th party encoder to prepare for import into the above mentioned programmes.
    Regards,
    Douglas
  • Fri, Oct 31 2008 7:40 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 3,108
    • Points 35,520
     Just had a quick look Douglas, came to the redoing part creating dvd versus creating bluray from a third party app when you say that you´ll have to redo all your editing when going from dvd to bluray.
    I Never do that, just to "save as" from Avid dvd, add the extension "blu" before the name of my project and drag the bluray encoded m2v file over the previous dvd encoded videofile, this way replacing it, the wav file stays untouched from the dvd project, a 30 seconds job, fast and easy, always works .
    Maybe those tips should be in the Avid DVD forum ?
    MC 4,03 ( Liquid 7,2 ) V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 8 GB, PNY Quadro 1800, Soundblaster X-Fi... [view my complete system specs]
    Tomas
  • Fri, Oct 31 2008 7:46 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
     Sounds like an interesting solution.
    Does that mean that any chapter points/ subtitles etc. that were on the 1st version are still there after you drag the Blu-ray encoded m2v file into place?
    Or do you have to redo them?
    Regards,
    Douglas
    Edit Added:
    Also, in my case, I don't have only 1 long clip imported. There are usually 12 to 20 shorter movies, each imported seperately.
    How easy is that to do in 30 seconds?
    Different types of jobs will have different types of solutions. In my case, I don't see that it would work.... but I am far from infallible Geeked
  • Fri, Oct 31 2008 8:21 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,108
    • Points 35,520
    drbgaijin:
    Everything in the menu stays the same, you are only changing source media, you can even do it in the same project but in this case, you´ll have to remember, or doublecheck everytime, if it is a dvd or bluray file that you have added to your timeline and we gets older and older right ? Smile
    Also, the differences in 2 pass encoding versus one pass might be more visible if you have bad source media from the beginning, I was working with such a project a couple of days ago and it was a huge difference.
    Tomas
  • Fri, Oct 31 2008 8:45 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    mjolnarn:
    ...............you´ll have to remember, or doublecheck everytime, if it is a dvd or bluray file that you have added to your timeline and we gets older and older right ?......
    Definitely getting older here. That part about "doublechecking" has convinced me that I should stick with the direct to DVDitProHD method. No need for an old man to doublecheck! Geeked
    mjolnarn:
    Also, the differences in 2 pass encoding versus one pass might be more visible if you have bad source media from the beginning.....
    I have no problems there as I am working with my own HDV source material only.
    I have never noticed any difference in Blu-Ray done with 2pass encoding vs. VBR with the encoding parameters set high enough.  If I look at DVD encoding I can see the difference between 1 and 2 pass .....
    Thanks for your input.
    For my part I will stick with what I am doing now.
    But it is useful for others to realise there are many approaches to this process (as I think I pointed pointed out in the above video)
    Regards,
    Douglas
  • Fri, Oct 31 2008 2:34 PM In reply to
    • maxvideo
    • Posts 47
    • Points 580
    BTW .. off - topic -don't want start new post ... Tomas - as I know you're using Canopus converter for preview at the external monitor. How it works with MC ?? Have you any AV delays on the external monitor  and speakers ? Any problems ?
    Max
    MC MojoDX 3.5.1, WinXP SP3,QT 7,6, HP XW8600 workstation / 2xXeon Quad Core 3,0 GHz, NVidia Quadro 3700, 4Gb RAM / Atto UL-5D SCSI controller with external... [view my complete system specs]
  • Fri, Oct 31 2008 6:03 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,108
    • Points 35,520
    maxvideo:
    Yes , a lot of delays so I cannot use it for syncing buth it works great for colour editing and other similar stuff as well of previewing all my work before exporting it out from the app, I use the FSP for checking sync, I actually run both FSP on one of my Syncmasters as well as previewing on my 42 inch plasma connected to the bob when i look at my finished work before exporting it.
    Edited later .
    i haven´t connected the audio to my plasma out from the bob, only the s-vhs connection , it might be sync on my plasma if I do so, will check
    Tomas
  • Fri, Oct 31 2008 6:25 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,108
    • Points 35,520
    mjolnarn:
    maxvideo:
    Edited later .
     Ok, just checked, it seems to be in sync when the audio also is connected to the bob
    Tomas
  • Fri, Oct 31 2008 6:45 PM In reply to
    • maxvideo
    • Posts 47
    • Points 580
    Thank you for your reply, Tomas. I work with external video monitor and Control L speakers / not with MC s/ware now/. If I  send a video and audio via Canopus  it  can be  in sync and  without  delays, as I  understand.
    Best, Max
  • Thu, Nov 13 2008 2:44 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    mjolnarn:
    drbgaijin:
    Everything in the menu stays the same, you are only changing source media...........
    Tomas,
    I don't have time to check that part just now.
    But - you say "Everything in the menu..."
    Do you actually mean menu?
    The chapter points/subtitles etc. are not part of the menu system - they are on the timeline for each Movie title.
    If you change the movie... do all the chapter points and subtitles remain in place?
    Regards,
    Douglas
  • Thu, Nov 13 2008 5:01 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,108
    • Points 35,520
    If you follow my workflow and just drag the " other " m2v file to the title window where the " brother " m2v is placed , you will get a warning from Avid dvd that you are going to replace the file , so, yes , all have stayed the same in the cases I have done that , the files are of the same type and at the exact same length , using the same audio file which you not should replace of course .
    If you will test some different menu constructions, there might be certain setups that this workflow not will function with altough I haven´t seen it yet but for ordinary bread and butter editing, I haven´t seen any probs .
    And this don´t take much time Douglas, you don´t have to take my word for it , you are familiar with the app , just do a fast test and tell if it worked as well for you  as for me .
    If you are afraid of destroying a long , nice and advanced menu you just have created , just go up and " save as " and start working in the other project in the same way that you are copying sequenses in MC and continue to work with the copied sequense  .
    Tomas
  • Thu, Nov 13 2008 5:23 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    Thanks Tomas,
    I just confirmed that it works as you said Geeked
    Just as an aside:
    This means I will now continue to use my workflow and strengthen it by remembering what you have pointed out for me.
    Soon I hope to have the 6th in my DVDit tutorial series done.
    After that, due to a couple of viewers requests , I will continue to go into more depth with DVDit, and your advice will be included in one of those new tutorials.
    Thank you.
    Regards,
    Douglas
  • Thu, Nov 13 2008 5:31 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,108
    • Points 35,520
    Douglas, it is always nice to be working together with you and making tests that in the end will come out as help for other users , you´re welcome ,  nice that it worked as well for you as for me , I really like that workflow .
    Tomas
