Latest post Tue, Oct 28 2008 1:47 PM by mikel. 2 replies.
  • Mon, Oct 27 2008 9:16 PM
    • mikel
    • Joined on Wed, Oct 19 2005
    • Toronto
    • Posts 53
    • Points 625
    conforming HD23.976 from SD23.976 ??
    Hello,
    here's a quick question. I'm trying to conform a project in the Nitris that was cut at 23.976p NTSC and is being finished as HD 1080p 23.976.
    I've made a new sequence that is HD1080p 23.976, and tried to decompose the shots and they all come out as 'SD 23.976p NTSC'. I've tried to transcode the clips to HD, and I end up with am SD clip that is a DNxHS resoltuion (which is weird in intself)
    When I go to capture, I get an error that says This clip cannot be batch captured because you are in a 1080p/23.976 project and this is not a 1080p/23.976 clipI'm just confused because if I've got shots in another project that is HD 59.94, and I've loaded them into a project as SD 29.97 for the offline, everything will pop back into place easily.
    anyone know what key piece I'm missing? thanks - Mike
    Unity since version one
  • Mon, Oct 27 2008 10:20 PM In reply to
    • EP@KMP
    • Posts 10
    • Points 140
    Re: conforming HD23.976 from SD23.976 ??
    If you look at the format heading on your Sequence does it say HD1080p/23.976? If you right click on the sequence and select modify you can change your set format choice to be 1080p/23.976. Once the sequence has been modified to HD then the clips should decompose as HD clips. It should have made a copy of the original SD sequence. Erik
  • Tue, Oct 28 2008 1:47 PM In reply to
    • mikel
    • Toronto
    • Posts 53
    • Points 625
    In my test, I have 3 SD clips. I flip to HD 1080p 23.976 and cut the clips on to a new sequence. When I decompose that sequence, I still have clips that are listed as SD 23.976p NTSC in the format colum.
    A - HA !!
    I just took the SD sequence, modified to HD and the decmop clips turned out to be HD. Thanks for the tip. The modify format did the trick.
