Latest post Sat, Dec 31 2011 1:20 PM by chumpster. 18 replies.
Page 1 of 2 (19 items) 1 2 Next >
  • Sat, Oct 25 2008 11:35 PM
    Exception: MSM: No directory specified_3
    After installing 3.0.5, restarting, then starting MC, all seemed to be starting up fine. Until I got the message above. MC quits. There is a reference in the Knowledgebase,
    "Trashed Media DataBases (msmMac.pmr and msmOMFI.mdb ) located in Avid MediaFiles in the Supported Files Folder of the Media Composer Software Folder."
    I can't tell what this means: there is no Supported Files Folder in the MC folder.
    Any help would be greatly appreciated. Thanks.
  • Sun, Oct 26 2008 4:42 AM In reply to
    Re: Exception: MSM: No directory specified_3
     This refers to rebuilding the media database files. On each media drive, there is an "Avid MediaFiles" folder and sometimes an "OMFI MediaFiles" folder at the root level of the drive. In each numerical folder inside the MXF folder inside the Avid MediaFiles folder, delete the two files that identify by type as "MSM Media Database". If you have an OMFI MediaFiles folder, delete the same two files. On re-launch, the system will detect the missing files and build new ones at the "Initializing Media Streams Manager" stage.
    Newscutter Nitris DX 9.5.3.3 * Media Composer 5.5.3.3 (At Home on PC) Symphony 6.0.1.1 (At home on MacBook Pro running 10.7.2) * Interplay 2.3 * ISIS/Unity... [view my complete system specs]
  • Tue, Oct 28 2008 8:58 PM In reply to
    I discovered a larger issue: I'd been trying to install 3.0.5 from the desktop where it had downloaded. I ran 'Launch', and got an error when trying to install the Suite. I was able to install just Media Composer, but got the Exception error when trying to start it up.
    The solution that solved all problems was to burn the downloaded 3.0.5 files to a DVD, and run 'Launch' from the DVD. The Suite installed with no errors, and the application ran correctly without the above error.
    Thanks for the help.
  • Tue, Oct 28 2008 9:17 PM In reply to
     Harry,
    There is a known resource conflict between MC 3.x and ProTools that results in malfunction of audio suite inside Media Composer. If you do have ProTools on your platform and this issue surfaces, remove it. Just FYI.
  • Wed, Oct 29 2008 7:06 AM In reply to
     Larry,
    that is not entirely correct. PRo Tools an MC 3.0.5 can exist on the same system (as mentioned on the digidesign website) I am having both on the same machine for a long (and several versions back) time without any problems. I also did not experience any installing errors whatsoever. The conflicts you are hinting at are individual cases, with a couple of different problems/solutions.
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 4x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC latest, Mojo... [view my complete system specs]
  • Fri, Feb 6 2009 2:50 PM In reply to
    • djustino
    • Joined on Fri, Feb 6 2009
    • Posts 2
    • Points 30
    Done that and nothing. I got the same exception error! :(
  • Fri, Feb 6 2009 4:57 PM In reply to
    Reposting here incase it helps someone.
    Found the solution.
    Went to Public>Public Documents and Deleted EVERYTHING there.
    Only then MC starts normal and recreates users and site settings.
    You will need the installation disc or folder.
    Proceed with your own risk and back up whatever needed:
    Attic Folder and User Settings at least.
    Desktop
    Zalman 600W/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.5/Corsair 16G DDR3/PNY Quadro 2000D(275.89)/WD VelociRaptor 300@10K(OS)/ 2x1TB Samsung F1@RAID 0/LG BH10LS30/Optiarc 7240S/W7 Pro 64bit/MC 6.0.1.1/Matrox MXO2 Mini/2xHP 22'' Monitors/M-Audio AV30 Speakers
    Laptop
    Clevo W170HN/i5 2410(2.30)/4G DDR3/Geforce GT 540M(296.10)/Liteon DS8A5S/W7 Pro 64bit/MC 6.0.1.1
    YouTubeVimeoLinkedIn
  • Mon, Mar 30 2009 1:39 PM In reply to
    I had the same problem on my MC 3.1 system this morning.  I found and deleted database files from here:  C:\Documents and Settings\All Users\Documents\Avid Media Composer\Avid_MediaFiles  (on Windows XP)
    It worked!!!  ...and I didn't have to delete ANYTHING else!
    HP z400 workstation Intel Xenon W3550 @ 3.07GHz 6 GB memory NVIDIA Quadro FX 3800 Windows 7 Professional 64 bit Avid MC 5 [view my complete system specs]
  • Fri, Apr 10 2009 10:52 AM In reply to
    • AllanC
    • Joined on Sun, Oct 21 2007
    • China
    • Posts 10
    • Points 120
    It Worked!
    ksmith0034,thanks!
    MacPro 3,1 Quadcore Xeon 3.3GHz GFX 8600GT LSI SAS HBA with 500GBx2 MC4.02 [view my complete system specs]
    Avid AAF confirms to Autodesk Smoke, awesomeIdea
  • Thu, May 14 2009 5:02 PM In reply to
    • jaaed
    • Joined on Sat, Feb 16 2008
    • Posts 15
    • Points 205
    ksmith0034:
    For the benefit of anyone running Avid on a mac and arriving at this thread via a search, more or less the exact same technique works there too.
    In my case the file was in the following folder:
    Macintosh HD/Applications/Avid Media Composer/Supporting Files/Avid_MediaFiles
    ... which I found by running a search for 'msm'.
    Home - Media Composer v5.5,OS X 10.6.6, MBP 17/CTO 2.6GHz Intel Core 2 Duo 4GB 667 DDR2 SDRAM - 2x2GB 320GB Serial ATA @ 7200 rpm SuperDrive 8X DL... [view my complete system specs]
  • Thu, May 14 2009 5:50 PM In reply to
    Just a note about rebuilding MSM Media Database Files.
    These are the circumstances that indicate a rebuild is necessary:
    1) You encounter media offline issues when you KNOW for sure that the associated media files are still on the system.
    2) You launch the media tool and the resulting bin comes up dead empty.
    3) You move a project and it's media from one stand alone platform to another.
    Rebuilding databases is NOT something you should do as routine preventative maintenance. Do it only when you need to.
  • Fri, May 15 2009 5:21 PM In reply to
    • IBL
    • Los Angeles, CA
    • Posts 32
    • Points 405
    Brilliant! Worked for me on a Mac Pro.
    MC 3.5.6 + SD Mojo OSX 10.5.5 Mac Pro 8-core 3Ghz 6 GB RAM [view my complete system specs]
  • Wed, Jan 13 2010 4:04 PM In reply to
    • Pud
    • Joined on Wed, Aug 8 2007
    • Posts 1
    • Points 5
    Hi, On VISTA,  I had to do the following to get rid of that error:
    Mouse drive C:, and select USERS, and work your way to Public Docs and delete the
    Media Media Files folder.
    That fixed it !
    Patrick
  • Tue, Mar 23 2010 9:01 PM In reply to
    • Stanislav
    • Joined on Tue, Mar 23 2010
    • Posts 2
    • Points 40
    Thank you for the idea. This is what helped me in MC 3.5.1. I got the same error message. Deleted index files on all media disks - no effect. Then discovered media directory in  \Documents and Settings\All Users\Documents\Avid Media Composer\Avid_MediaFiles Deleted index files (msmFMID.pmr, msmMMOB.mdb)
    ... and it worked!
  • Tue, Mar 23 2010 9:06 PM In reply to
    Stanislav:
    I just want to point out to the community that the above highlighted folder does NOT contain associated media files. It contains files necessary for the UI itself to run correctly, so it is normal for that particular folder with the underscore in the name to live on the C: drive. Not to be confused with "Avid MediaFiles" folders which contain associated media files and should always live on separate media drives.
Avid Technology, Inc. brands:
M-Audio  |   Sibelius  |   Pinnacle Systems  |
