Latest post Tue, Oct 21 2008 6:11 PM by PeteEdit. 2 replies.
  • Mon, Oct 20 2008 9:39 PM
    DVD it file sizes
    Hello I am having trouble with getting my files to DVD it.  After compressing a file into .wav format it is now 2.5 GB.  Once I pull it into DVD it it is 2.5 GB.  Then I pull it into the project and now the dvd project size becomes 12.31 GB.  Why is this happening?  What am I doing wrong?
    Dell Precision T3400 XP Pro Core 2 Quad 2.4GHz 3.25 GB of RAM (really 4 but xp only recognizes that much) [view my complete system specs]
    Joshua Gross
    Coordinator of Media Support
    The University of Akron School of Law
  • Mon, Oct 20 2008 10:09 PM In reply to
    • kutter
    • Joined on Sun, Jun 17 2007
    • Phoenix, Arizona
    • Posts 74
    • Points 910
    Re: DVD it file sizes
    Joshua, I'm not sure what the problem is, but here's what I do.  I export out of my media composer as a QuickTime reference file.  I then drag the movie file (I don't worry about bringing in the audio file that is createdbecause it automatically comes with the movie file ) into DVD it.  I make my  buttons, And then compress.
    Kent
    hp workstation xw8200, SP2, 4 gbs ram, 3.40ghz, Symphony Nitris 1.8.3, XP Pro, QT 7.3.1 MCSoft 3.0.1 Apple G5 dual 2.0 O. S. x 10.4.11 ... [view my complete system specs]
    Kent Kreiger
    ACI
    Kreiger Post - Metropolitan Post
    http://www.kreigerpost.com
  • Tue, Oct 21 2008 6:11 PM In reply to
    • PeteEdit
    • Joined on Sat, May 20 2006
    • Posts 60
    • Points 950
     Hi Joshua,
    What you are experiencing is actually just the strange way DVDit works.
    What is happening is - DVDit is seeing your file as non-compliant. This means DVDit wants to transcode the file. If the transcode settings are too high, DVDit shows a file size that is too high.
    Here's more detail - By default, DVDit wants to transcode at 8.0mb. Go into the transcode settings to see this. If you lower the settings to say - 4.0, you will see the 12.31gb setting go WAY down. Play with the number until you get it right.
    Even with files that ARE compliant, DVDit usually wants to re-transcode. It is just the way it works. There is no way around it!
