It would be nice if we could change the default dissolve speed from the 30 frames to a user assigned amount so it is set that way everytime we start Media Composer 3. Say for example 15 frames (7 frames on each side)?
I know I can change it once I get the quick dissolve window open, but I was looking to save myself some time changing it everytime I restart avid. We tend to find the 15 frame dissolve works better for us and use it almost 100% of the time. That is why changing the default dissolve setting would be helpful to us.
System #1 HP z800 Workstation dual 6 core CPU Win 7 64bit 12GB of RAM with Nitrix DX
System #2 HP z800 Workstation dual 6 core CPU Win 7 64bit 12GB of RAM with Nitrix DX
Create your 15 frame centered on cut dissolve
Create a bin called exactly this:
Quick Transitions
open the effect editor and save the effect to the bin
Name the effect.
Save and close the bin.
now whenever you have that bin referenced in your project you will have your 15 frame transition available in the dropdown menu.
this works for just about ANY transition effect. Boris, Sapphire, Avid, as long as it is saved in your Quick Transitions bin and is referenced in your current project.
Happy Editing!
Avid Technology, Inc. brands: M-Audio | Sibelius | Pinnacle Systems |
