Latest post Tue, Oct 14 2008 7:55 AM by FSD. 7 replies.
  • Tue, Oct 14 2008 3:33 AM
    • Strider
    • Joined on Fri, Sep 1 2006
    • Los Angeles
    • Posts 100
    • Points 1,485
    How to make seperate audio & video into one within avid and work with them like an imported ideo?
     I have a video sequence and an audio sequence both of 1 1/2 hours. I imported both into Avid and they sync up in the time line. Now I want to mix them down together and end up with one movie that I can then have in my composer window and can edit into my timeline just like any other movie you import into Avid. Is there a way to do this without having to export and then re import the whole sequence with both audio and video. Hope that makes sense. It will save a lot of time if anyone can help.
    Strider.
    Intel(R) Xeon(R) CPU 5130 @ 2.00GHz 2.00Ghz, 3.00GB of RAM [view my complete system specs]
    STRIDER
  • Tue, Oct 14 2008 3:43 AM In reply to
    • outpostbc
    • Joined on Tue, Feb 21 2006
    • Lenexa,KS
    • Posts 280
    • Points 3,450
    Re: How to make seperate audio & video into one within avid and work with them like an imported ideo?
    Could you use the autosync command. I am away from my Avid right now but I think it is under clip heading. You can sync by timecode, in point or other various methods.
    Media Composer Nitris DX 4.0.2 Dual 3GHz Mac Pro 4GB Ram 10.5.7, Symphony Nitris DX 4.0.2 Dual 3GHz Mac Pro 4GB Ram 10.5.7, Unity MediaNet 5.1.3 [view my complete system specs]
  • Tue, Oct 14 2008 3:47 AM In reply to
    • Strider
    • Los Angeles
    • Posts 100
    • Points 1,485
     Thanks but I couldn't find it under clip (or in the other tabs). Under clip it has audio mixdown and video mixdown but not both together to make a new movie I can use.
    STRIDER
  • Tue, Oct 14 2008 3:59 AM In reply to
    • outpostbc
    • Lenexa,KS
    • Posts 280
    • Points 3,450
    Are you working on MC or Xpress pro? If you on express pro, you won't find that feature, it is only on MC. You could always just export a QT Ref and reimport. Hope that helps.
  • Tue, Oct 14 2008 4:24 AM In reply to
    It should be in Xpress Pro under the Bin menu.
    MC 3.1.3, Intel i7 920, Vista 64 bit, Nvidia GTX 275, 6 GB of RAM, X-Fi Titanium Professional, MSI X58 SLI Platinum. [view my complete system specs]
  • Tue, Oct 14 2008 4:28 AM In reply to
    • outpostbc
    • Lenexa,KS
    • Posts 280
    • Points 3,450
    Dom Q. Silverio:
    Thanks- I looked in my version of Xpress pro and didn't find it, but I am running ver 4.6.Embarrassed
  • Tue, Oct 14 2008 4:51 AM In reply to
    • AquaPix
    • Joined on Sat, Sep 16 2006
    • UK
    • Posts 447
    • Points 5,555
     I am not in front of my Avid, but I think if you copy the sequence into your clipboard monitor, left click the monitor with your mouse and drag it to the bin you want, the Avid should create a new clip.
    MC3.0.5, QT7.4.5, Vista Business x64, Intel Quad Core Q6600 @ 3.4GHz, Asus P5K Mobo, 8GB RAM (OCZ Reaper @ 950MHz DDR II), GeForce 8800GTX (multithreading... [view my complete system specs]
     Andy Lange www.aquapix.tv
  • Tue, Oct 14 2008 7:55 AM In reply to
    • FSD
    • Germany
    • Posts 128
    • Points 1,520
     yes, you mark your sequence and copy the whole thing with "alt+c" to your sourcemonitor or you drag the sequence while presssing "alt" from your recordwindow to your bin, this will create a sub sequence which you can load to your source moniter and so on..,
    G5 Dual Core 2Ghz, 5 GB, MC 3.1.3 + Mojo, MacOSX 10.4.11, QT 7.4.5 [view my complete system specs]
