Latest post Fri, Oct 10 2008 2:19 PM by mBlaze. 2 replies.
  • Thu, Oct 9 2008 8:10 PM
    deep techie question
     Hey,
    If i render a clip 2;1, then mix it down, does it recompress again  at 2:1 or does it use the media already created at that resolution to make the mixdown?
    thanks
    MC Asus PC-DL Deluxe M/B Dual Xeon procs Mojo Striped Raid, Fast drives, separate System drive [view my complete system specs]
    www.whirlwindfilms.com www.spencerdoane.com
  • Fri, Oct 10 2008 12:49 AM In reply to
    • Chad
    • Joined on Fri, Oct 14 2005
    • Sydney, Australia
    • Posts 101
    • Points 1,170
    Re: deep techie question
    I'm pretty sure it 'copies' it.  I did some difference matte tests in Photoshop a while ago to try and answer this very question, and the mixed-down and unmixed-down frames were identical (at least visually)
    Anecdotally, the speed of mixing down rendered vs. unrendered effects would also support this conclusion - but I guess we'd need an Avid developer to see this thread before we get a definitive answer.
    Avid MCA 3.0 on WinXP SP2 3Gb RAM [view my complete system specs]
  • Fri, Oct 10 2008 2:19 PM In reply to
    • mBlaze
    • Boston
    • Posts 374
    • Points 4,260
    It only recompresses it if you add another composite layer before doing the mixdown. The same is true with a submaster effect - if you drop it over a master clip and do a render, it should just copy the media of the master clip into the submaster render.
    Avid Media Composer Mac [view my complete system specs]
    James Burke
    mBlaze Multimedia Design, Inc.
    On Tape, On Disc, Online.
    The Spark Starts Here.
    www.mBlaze.com
