Latest post Fri, Oct 10 2008 2:09 PM by mBlaze. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Oct 6 2008 1:50 AM
    • chrischen
    • Joined on Fri, Jan 26 2007
    • Posts 43
    • Points 505
    Apple Animation Codec
    I've been told to export a video in Apple Animation codec at 720x480 size.
    How do I do this in Media Composer?
    I went into export and clicked on custom and set the compression to Animation. Is that the Apple Animation Codec? Thanks.
    Macbook Pro 15.4" 2.4 Ghz 4GB Ram GeForce 8600 256 mb Intel Core 2 Quad Q6600 2.4 Ghz 3GB Ram Geforce 8500 256mb [view my complete system specs]
  • Mon, Oct 6 2008 5:18 AM In reply to
    Re: Apple Animation Codec
    Yes it is... you are all set.
    MC 2018.9, Blackmagic UltraStudio 4K, 12-Core MacPro, 64 GB RAM, 24 TB Thunderbolt Storage [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc
  • Fri, Oct 10 2008 1:43 AM In reply to
    • chrischen
    • Posts 43
    • Points 505
    Ok I got a response from them saying the video was low-res and the audio was out of sync. I set it at that resolution I stated above so what could be the problem?
  • Fri, Oct 10 2008 3:02 AM In reply to
    Well... there's more to it than simply selecting Animation.  You have to choose the quality, audio compression, etc.  In your export settings, click format options... then click settings for video... be sure the Animation Codec is selected, be sure the Quality is at %100 or Best.  Then click the settings for Sound.  Be sure that is set to None.  Be sure you have it at 48khz or 44.1khz, whatever matches your project.  See attached pic.
    All that said... the best quality you can give them is a QT MOV file, exported Same As Source.  This will use the Avid codec.  It will be a smaller file and look better.  If they cannot use the MOV file, it's simply because they do not have the Avid Codec.  It's free... download it and include the installer with the delivery of your QT files.  I always include the Avid Codec Installer, for both PC and Mac, with all Avid compressed QT files I deliver.
  • Fri, Oct 10 2008 6:09 AM In reply to
    • chrischen
    • Posts 43
    • Points 505
    Ok I'll see if they can take the Avid Codec, however I did select best quality yet and 720x480 resolution yet it the video still turned out abnormally and extremely large.
  • Fri, Oct 10 2008 6:33 AM In reply to
    • chrischen
    • Posts 43
    • Points 505
    Also what if I don't use the Avid DV codec?
  • Fri, Oct 10 2008 2:09 PM In reply to
    • mBlaze
    • Boston
    • Posts 427
    • Points 4,905
    If the place you're sending the video to can import Avid codec QuickTimes, your best bet is to export out "Same as Source".
    Unless things have changed with the codec, they're free to distribute, so you could send along the codec as well.
    Avid Media Composer 7.0.3 on MacBook Pro 2.5GHz Intel Core i7 [view my complete system specs]
    James Burke
    Video Producer / Editor / Designer
    blog.DVfanatics.com
