Latest post Fri, Oct 3 2008 5:15 AM by tompearson. 3 replies.
  • Thu, Oct 2 2008 8:17 PM
    • weekender
    • Joined on Thu, Jan 4 2007
    • Vancouver, Canada
    • Posts 16
    • Points 270
    My DV tape's timecode got reset in the middle of the tape. How can I batch capture?
    While filming with my Sony HVR-A1u camera, I must have either taken this particular tape out or rewound it to view it, (and then continued recording,) but at that point, the timecode got reset on it. The beginning of this particular tape starts at 00:00:00:00 but runs until 00:20:04:00 and at that point resets at 00:00:00:00 (which is where I either removed the tape or made a blank space on the tape,) and then finishes at the end of the tape at 00:45:03:00. An this is how Avid captured it.
    My goal is to edit in this DV25 format and later batch capture the final sequence in HDV. Will batch capturing be possible when it tries to find clips in this tape? ie/ if it's trying to find a clip that's at 00:10:00:00, it could take it now from 2 spots on the tape!
    Will batch capturing not work for this tape or is there something I can do to work with this situation?
    Windows XP Pro SP2 Avid Media Composer 3.0 Quicktime 7.5 Intel Core2 Quad CPU @ 2.4GHz 4 GB Ram NVIDIA GeForce 7300 GT (512 MB) Video Realtech HD... [view my complete system specs]
  • Thu, Oct 2 2008 8:38 PM In reply to
    • mBlaze
    • Boston
    • Posts 374
    • Points 4,260
    Re: My DV tape's timecode got reset in the middle of the tape. How can I batch capture?
    A tip that I believe Steve Bayes suggested is renaming the tape for the area that has duplicate timecode so that Avid prompts you to reload the tape.
    So the first part of the tape would be named TAPE01 and the second part of the tape would have the tapename TAPE01B.
    Make sure that the tape is cued in the first part when loading TAPE01 and make sure the tape is cued in the second part when loading TAPE01B.
    Avid Media Composer Mac [view my complete system specs]
    James Burke
    mBlaze Multimedia Design, Inc.
    On Tape, On Disc, Online.
    The Spark Starts Here.
    www.mBlaze.com
  • Fri, Oct 3 2008 4:19 AM In reply to
    • weekender
    • Vancouver, Canada
    • Posts 16
    • Points 270
    Any idea why the timecode reset itself on this tape? I wonder if I will have the same issues with many of my other 60 tapes because of something I did while filming.
  • Fri, Oct 3 2008 5:15 AM In reply to
    • tompearson
    • Joined on Thu, Mar 1 2007
    • Wayzata MN
    • Posts 578
    • Points 6,230
     set your camera to record run and not to reset  and was the tape used beforethat can happen with used tapes
    asus mb p5wd2 dualcore 3 gig intel cpu's 4 gig crucial ram nvidia quadro fx 3500 1 tb wd sata 7200 raid 0 seagate 160 gig sata 7200 os drive mojo command... [view my complete system specs]
    Tom Pearson Director Hollywood-sounds.com
