Latest post Mon, Oct 13 2008 12:04 PM by DKGen. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Oct 2 2008 2:46 PM
    • shandy13
    • Joined on Fri, May 30 2008
    • Posts 12
    • Points 155
    editing from dvd material
    hi there,
    I'm an editor and unfortunaltely quite low tech, so i wonder if anyone could give me some general advice here regarding how to get DVD material into my avid to edit (I work on an avid xpress HD, v5.2 on a pc ,without a mojo and have no immediate plan to upgrade to anything else, as i only use it for very low budget things and showreels). i need to edit a new showreel and all my material is on DVDs which  (I guess) I would need to rip as an AVI or QT to get into the avid as i don't have a mojo. I've used Auto GK before but found that i only seem to rip the whole of the DVD with this software which takes forever. is there any free software out there which lets me rip only part of a DVD or is there any other way of importing from DVD?
    sorry for posting such a basic question. I really apreciate your help. thanks
    shandy
  • Thu, Oct 2 2008 3:00 PM In reply to
    • FSD
    • Germany
    • Posts 128
    • Points 1,520
    Re: editing from dvd material
     Try mpeg streamclip from  www.squared5.com where you can set ins and outs.
    but mind the copyrights of the DVDs you need to rip.
    G5 Dual Core 2Ghz, 5 GB, MC 3.1.3 + Mojo, MacOSX 10.4.11, QT 7.4.5 [view my complete system specs]
  • Thu, Oct 2 2008 5:14 PM In reply to
    • shandy13
    • Posts 12
    • Points 155
    Hi FDS
    vielen dank for that. I've downloaded the software and done a few trial runs with several DVDs. It doesn't seem to work with all them (i guess it might have something to do with copy right protection, the software crashed a few times). but for those DVDs it did work: very impressive quality.
    thanks again
  • Thu, Oct 2 2008 5:29 PM In reply to
    • camoscato
    • Posts 6,093
    • Points 73,065
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Cinematize is good for DVD ripping.
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Thu, Oct 2 2008 6:06 PM In reply to
    • Philavid1
    • Joined on Thu, May 11 2006
    • Quebec, Canada
    • Posts 55
    • Points 590
     Hello, if your product does not have to be top quality, you could buy a analog to firewire (DV) converter, you can get them for approx 100 dollars, you will digitize real time, and if the box is bi-directional, you will have DV output for preview on an analog monitor. Just be aware that if you work on firewire drives you should get a 2nd firewire card for this converter box (PYRO FIREWIRE 400 PCI CARD WORK BEST)
    Phil
    1 Media Composer software 3.0 on xw4400 workstation 2G Ram, Quadro FX1300 video card 1TB Local storage on Raid 0 Lacie Firewire 800 drives. SIIG PCI firewire... [view my complete system specs]
  • Fri, Oct 3 2008 12:08 PM In reply to
    • shandy13
    • Posts 12
    • Points 155
    thanks Phil, that's really helpful, I'd never heard of that converter before. i'll look into it.
    Shandy
  • Fri, Oct 3 2008 12:10 PM In reply to
    • shandy13
    • Posts 12
    • Points 155
    thank you very much
  • Mon, Oct 6 2008 11:06 AM In reply to
    • DKGen
    • Joined on Mon, Sep 10 2007
    • Posts 129
    • Points 1,415
    I have a simillar project this week.  Being sent a DVD to edit a promo from the material.  I used to just hook up my DVD player via analogue out and connect it to a DV deck and get the whole DVD on to tape and then work from that tape.  Is that still an acceptable way?
    HP XW8400 Workstation Dual 2.66GHz Xeon 3.00 GB RAM Quadro FX 1500 256 MB Avid XPPro v5.7.2 After Effects CS3 3ds Max 9 XP SP2 [view my complete system specs]
    HP XW8400 Workstation Dual 2.66GHz Xeon 3.00 GB RAM Quadro FX 1500 256 MB Avid XPPro v5.7.2 Mojo SDi XP SP2 G-tech Raid 1 TB Max 9 AE CS3 HVR M15E HPLP2465 JVC TM-H1750C CRT Monitor Samsung 40" LCD
  • Mon, Oct 6 2008 11:50 PM In reply to
    • camoscato
    • Posts 6,093
    • Points 73,065
      Moderator: Meridien
    DKGen:
    Yes, that method is fine.
    good luck,
    Carl
  • Tue, Oct 7 2008 12:50 AM In reply to
    • gumbaedit
    • Richmond, VA/Los Angeles, CA
    • Posts 99
    • Points 1,425
    Download a program called mpeg streamclip.  It will allow you to open up the dvd TS folders and then convert it to any movie format you want.  Then you just import it into Avid.  Depending on your system, it may take a bit longer than digitizing straight of the dvd, but should you lose your media, or need to reimport it, you edits will stay intact, as opposed to didging with no TC.
    8 core MacPro 3.0, Mojo SDI, MC 3.1.3, Sonnet 4TB RAID with Tempo SATA E4P, Panasonic BT-LH1710. [view my complete system specs]
    I use Avid and FCP.  I curse about both companies equally on a daily basis.
  • Mon, Oct 13 2008 12:04 PM In reply to
    • DKGen
    • Posts 129
    • Points 1,415
    Thanks...  I think I'll stick to the tried and tested straight to tape method I used to use.  I'm always a bit sceptical about recompressing compressed clips with software I'm not familiar with.
    Regards
