Latest post Sun, Sep 28 2008 3:42 PM by Gabagandi. 4 replies.
  • Sat, Sep 27 2008 3:26 PM
    • Gabagandi
    • Joined on Sat, Sep 27 2008
    • Germany / Hamburg
    • Posts 3
    • Points 35
    Batch capture from 2 to 4 audiotracks
    I captured some Footage(digital Betacam) with 1 Videotrack over SDI and 2 Audio Tracks via RCA
    that was unfortunatly a mistake, and now I need to batch capture the audio tracks again via SDI and add the two missing audiotracks. Is this possible? I tried already to modify the Data for 4 Tracks but everytime I tried to batch capture it the capture tool jumps Back to 2 Audiotracks and starts capturing.
    Is it possible to add Audiotracks this was to an already existing File, or do I have to capture and recut all the stuff again??
    thanks
    HPxw8400 QC..  Mc.3.0
  • Sat, Sep 27 2008 3:45 PM In reply to
    Re: Batch capture from 2 to 4 audiotracks
    Go to Settings > Capture > Batch > "Capture the tracks logged for each clip" ...
    Turn this off.
  • Sat, Sep 27 2008 4:46 PM In reply to
    • Gabagandi
    • Germany / Hamburg
    • Posts 3
    • Points 35
    I turned it off allready, thats actually my problem, perhaps i wasnt specific enough, sorry.
    When I turn it off, im able to activate the audiotracks 3 and 4 in the capture window, but when Im starting to batch, the avid jumps back and deactivades the third and fourth audiotrack and starts to capture only the stuff I've already got
    but thanks anyway
  • Sat, Sep 27 2008 4:59 PM In reply to
    Highlight the clips in the bin.
    Hit Delete.
    Choose 3 Associated media Files
    (there's really no reason to delete the video track, but the re-capture process is going to take the same amount of time regardless, so just go ahead and delete everything)
    De-select Master clips
    Hit ok to delete all the media for these clips.
    With all the clips still highlighted, Hold CTRL+SHIFT and right click on the clips.
    Select Unlink
    make sure all clips are selected and right click
    Choose Modify
    Choose Set Tracks.
    Choose V1 A1-4
    Hit ok.
    batch capture bin.
    MC 2.5.1 with Analog Mojo. HP xw8000, dual 3.0 Xeon, 3 Gig Ram, nVidia FX1100, ADS Pyro Firewire Card. [view my complete system specs]
  • Sun, Sep 28 2008 3:42 PM In reply to
    • Gabagandi
    • Germany / Hamburg
    • Posts 3
    • Points 35
    this one worked.
    thank you very much.
