Latest post Sat, Sep 27 2008 6:36 PM by raspago. 7 replies.
  • Fri, Sep 26 2008 6:05 PM
    Anybody using Quicktime 7.5 with MC 3.0 ?
    I have had huge problems since I upgraded to MC 3.0 (PC) and Quicktime 7.4.5 with renders, exports, imports, transcodes... I read I should install Quicktime 7.5. Has anybody tried this version of Quicktime ? Are there any issues ?
    HP xw8400 - Media Composer Adrenaline HD / HP xw8200 - Media Composer Mojo / 4TB EditShare shared storage [view my complete system specs]
    Pierre Corbeil
  • Fri, Sep 26 2008 6:54 PM In reply to
    • camoscato
    • Posts 4,683
    • Points 55,805
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Anybody using Quicktime 7.5 with MC 3.0 ?
    corbeilproduction:
    No, you shouldn't.  According to the Version Matrix you should be on 7.4.5.  If you can tell us what sort of problems you're having we might be able to help.
    good luck,
    Carl
  • Fri, Sep 26 2008 9:39 PM In reply to
    • dor
    • Israel
    • Posts 212
    • Points 2,685
     Hi
    7.4.5 is the official version, but it crash a lot when trying to change some settings in the QT export.
    Some one of this forum wrote that QT 7.5 did fix this problem over his side.
    As I was having the same problems I have installed QT 7.5 too and since then I have no more QT export problems. Some more user on this forum has reported that QT 7.5 solved thier problem too.
    MC 3.0.5 + MOJO SDI. Q9450+4GB RAM. 8800GT. XP PRO SP3 [view my complete system specs]
  • Sat, Sep 27 2008 12:59 PM In reply to
    • cuervo
    • Joined on Fri, May 2 2008
    • Posts 125
    • Points 1,665
    I use QT 7.5. So far, I have not run into any problems; and, I push my system pretty hard.
    Media Composer 3.05 on Win XP Pro SP3 - Intel x48, dual core quad 6600 - 4Gb RAM - PNY Quadro FX1700 - Echo Mona [view my complete system specs]
    Chalchihuitl Productions Music video, Digital Imaging JVC HD110--Sony EX1
  • Sat, Sep 27 2008 5:30 PM In reply to
    • zshad
    • Posts 11
    • Points 155
     Try the suggestion on this post.
    http://community.avid.com/forums/p/63368/355925.aspx#355925
    It worked for us. Now our engineers want to go back to 7.4.5 using the setting posted. I will not be able to get on the box until tuesday but I will post our results.
  • Sat, Sep 27 2008 6:18 PM In reply to
    • raspago
    • FL, USA
    • Posts 892
    • Points 11,005
    • Moderator: Spanish Language
    .- I'm another one of them.
    Custom made Intel core 2 duo 2.4 (overclocked to 3.0) Nvidia 8800GS, 3GB Ecc Ram, E-MU 1212M Sound card, Sata Drives, Analog Mojo. [view my complete system specs]
  • Sat, Sep 27 2008 6:20 PM In reply to
    The link zshad posted is a "safer" alternative for those not wanting to live in the danger zone outside of qualified versions.
    You can stay at 7.4.5 and change one of the QT pref settings
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Sat, Sep 27 2008 6:36 PM In reply to
    • raspago
    • FL, USA
    • Posts 892
    • Points 11,005
    .- At least in my personal case, I try to never get outside the "qualified" zone.
    Unless the qualified version is not working for me.
    And it happens.
    And not because the Tech people at Avid are doing a bad job but because they couldn't possibly test a version it didn't exist at the moment of the qualification.
    They have to certificate what exists, they have no choice.
    But sometimes in extreme cases I can't wait for them to test and qualify the newest version.
    OSX 10.5.3 and 10.5.4 sucked so incredibly bad I didn't care if 10.5.5 was unqualified.
    Simply put, the situation couldn't be worse.
    But turned out that 10.5.5 (the unapproved version) improve the things.
    Yes, still sucks but much, much less.
    Maybe 3.0.5 will fix Leopard for good.
