Latest post Fri, Sep 26 2008 10:16 PM by vvp. 7 replies.
  • Wed, Sep 24 2008 12:01 AM
    • vvp
    • Edmonton, Canada
    • Posts 623
    • Points 7,560
    Nitris DX Question
    I have a Nitris DX.
    The HD SDI A (LED) flashes green/amber regardless to what HD project type I am in 1080i or 720p.
    According to the install disk this means "Green/Amber: HD-SDI input A selected, input missing or incorrect format."
    To date, I have not been able to successfully output an HD project with the Nitris DX (SD projects are OK).
    Do I have a warranty issue or is it somthing else?
    Thanks for the help.
    So my new wife asks me about my "Avid Forever" tattoo... I told her she's an old girlfriend who was always coming up with new things for me to try...
  • Wed, Sep 24 2008 12:17 AM In reply to
    • zshad
    • Posts 11
    • Points 155
    Re: Nitris DX Question
     What deck are you outputting your HD and SD signals to?
  • Wed, Sep 24 2008 4:33 PM In reply to
    • vvp
    • Edmonton, Canada
    • Posts 623
    • Points 7,560
    HD: Sony HDW-2000 and Panasonic AJ-HD1400
    SD: Sony DVW-500
    Thanks for your thoughts.
  • Wed, Sep 24 2008 6:26 PM In reply to
    vvp:
    Why would the INPUT problem keep you from OUTPUTTING?
    Are you able to digitize from your HD deck via HD-SDI ok?
    What kind of problems do you have when "outputting"?  it won't digitial cut?
    what resolution are you at?
    MC 2.5.1 with Analog Mojo. HP xw8000, dual 3.0 Xeon, 3 Gig Ram, nVidia FX1100, ADS Pyro Firewire Card. [view my complete system specs]
  • Wed, Sep 24 2008 7:34 PM In reply to
    • AK-Jake
    • Leesburg, VA
    • Posts 2,475
    • Points 30,735
    • Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    vvp-
    Have you bounced this issue off of your reseller?  Issues like this are one of the main reasons you buy through a reseller...one phone call and they can usually fix the problem for free, or offer a reduced price for further support.
    HP xw8000, dual-3.06 ghz Xeon's; 2 GB of RAM; Nvidia QuadroFX 1100 AGP 8x Graphics Card; 1 - 160 GB 7200x IDE Hard Drive; 1 - 400 GB 7200x IDE Hard... [view my complete system specs]
    I think my memory sucks, but I forget.
  • Wed, Sep 24 2008 11:19 PM In reply to
    • vvp
    • Edmonton, Canada
    • Posts 623
    • Points 7,560
    Yes I have. :(
    They don't have a demo system set up to recreate the problem and are suggesting that I call Avid as they can't help with this.  Am I PO'ed? ... yup!  Anyway, a call to Avid is in the works, I have to find a slot in the day where I won't be interrupted 50 times while I do it...
  • Thu, Sep 25 2008 2:21 AM In reply to
    • zshad
    • Posts 11
    • Points 155
     Not sure if this is related but when we first had or DX installed, the video outputs sync needed to be sent to reference I believe. If it wasn't we could only out put scrambled video and the channel condition would light up. On that note does anything go to tape or do you just get the error indicator? I'm not at work right now but I will check the exact name of that setting later.
  • Fri, Sep 26 2008 10:16 PM In reply to
    • vvp
    • Edmonton, Canada
    • Posts 623
    • Points 7,560
    I can crash record HD out but I can't digital cut HD, thats when I get the error message.  I have a deck coming Monday to try it all again... sigh...
