Latest post Mon, Sep 22 2008 3:33 PM by freshstyles. 0 replies.
Page 1 of 1 (1 items)
  • Mon, Sep 22 2008 3:33 PM
    Batch Capture without discarding the original media??
    I have a TX master which has been mixed from 5 sources. It has no sound, and there are some errors in the mix. I need to correct the errors and replace the sound. I need to produce group clips with the TX leading and the picture and sound from the 5 other sources - based on the original TX captures. All timecodes on all sources are synced so i figured I could do something along the line of this
    1 - Copy TX captures into another bin
    2 - Batch capture with a different source tape to create an exact match, just on the one camera
    3 - Repeat 2 for the remaining sources
    4 - Sync all sources to create the group clips I need
    When I attempt to batch capture I can only do this by replacing the offline media (I want to keep the original online) or discarding the original media (I want to keep the original).
    Does anyone know a way around this, or a better workflow to achieve the same result??
    Any help well received!!
    Cheers
