Latest post Mon, May 12 2008 4:11 AM by tikboy. 26 replies.
Page 1 of 2 (27 items) 1 2 Next >
  • Mon, Jan 2 2006 10:21 AM
    • tikboy
    • Posts 236
    • Points 2,775
    Audio Suite Crashes Avid
    Ok.
    I've got a new computer built complying  to the recommended specs of AvidStudio.
    It was running really fast for the past days. I have started editing a project.
    I've already done some audio sweetening using the audio suite.
    This morning when I open the project and continued working. When I was trying to open the audio suite tool, Avid suddenly crashed! - the PC totally blacked out and restarts by itself.
    I tried it again and the same thing.
    Any clues?
    Thanks.
    P4 3.2 GHz | 2 G RAM | WinXP Pro, SP2 | Avid XP Studio Essential (5.2.1.2910) - Internal SATA hard drives - G-Raid firewire/usb drive - Swappable hard... [view my complete system specs]
  • Tue, Jan 3 2006 6:55 AM In reply to
    Re: Audio Suite Crashes Avid
    Thats happened to me as well.  Un-installing Pro Tools LE and Re-Installing it solve the problem for me.  Its a driver issue.
  • Wed, Jan 4 2006 7:07 AM In reply to
    • tikboy
    • Posts 236
    • Points 2,775
    I want to make clear that this was all done inside Avid.
    I have not launched or used PTLE for this project. I applied a normalize plug-in form AudioSuite and rendered it. But when i got back the next day, that's when it startS crashing.
    BTW, I have finished my video...thanks God! I haven't tried it again since.
    ...just makin sure before I do any action steps....How about installing the AXP upgrade to 5.2? I've downloaded it, just waiting for the right time.
    How would you reinstall just the PTLE? The CD just auto install the whole thing. I got Studio Essential, ONE installer DVD.
  • Wed, Jan 4 2006 5:57 PM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 3,746
    • Points 41,690
    • Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    The install menu should give you the option to install each component individually...btw...it looks like you need a bit more Ram...
    Dell Precision 650, 3.06 Ghz, 2 SCSI drives, 600 GB LaCie D2, 1.5 Mb Ram, Nvidia FX500 Suite 1. Avid Media Composer v3.0, Avid Studio Toolkit v 5.7... [view my complete system specs]
  • Thu, Jan 5 2006 3:07 AM In reply to
    • tikboy
    • Posts 236
    • Points 2,775
    Thanks Adman,
    So you think it is the PTLE that's causing the problem? BTW, I've just updated my system specs.....I think I have enough RAM (2 G).
    God bless.
  • Thu, Jan 5 2006 5:37 AM In reply to
    Even though you are not using PT LE within Xpress Pro HD, the Audio Suite still references drivers that PT LE shares with Xpress ProHD.
  • Mon, Jan 9 2006 9:19 AM In reply to
    • tikboy
    • Posts 236
    • Points 2,775
    Hi.
    Ok, I did:
    1. Uninstalled PTLE.
    2. Re-installed PTLE.
    Now, launching the ProTools application crashes the system. AvidXPro and others runs fine. Does this sound like REINSTALL the whole thing?
    How about installing XP 5.2? I have it downloaded and ready.
  • Mon, Jan 9 2006 2:33 PM In reply to
    • dthompson
    • Avid Technology
    • Posts 66
    • Points 960
    • Avid Customer Service
      Avid Employee
    If you're getting hard crashes and BSOD's then this is a known issue relating to Micorosoft's Service Pack 2 and the Data Execution Prevention feature they introduced. The easiest way to resolve the issue is to update your pace drivers at www.paceap.com.
    Lets us know if that fixes it.
    Best Regards,
    Xpress Studio Essentials HD w/ Xpress Pro v5.2.3 HP XW4100 Windows XP Pro SP2 P4 3.0 Ghz 1.5 Gb ram Nvidia Quadro4 980XGL [view my complete system specs]
    ~David R. Thompson~ ACSR|Windows ACSR|Macintosh ACSR|Unity Avid Technology, Inc.
  • Tue, Jan 10 2006 3:34 AM In reply to
    • tikboy
    • Posts 236
    • Points 2,775
    Thanks Mr. Thompson.
    It is just a black screen before it restarts. No BSOD really. Do you think it is still the same thing?
  • Tue, Jan 10 2006 1:58 PM In reply to
    • dthompson
    • Avid Technology
    • Posts 66
    • Points 960
      Avid Employee
    Ya...I've seen both caused by not updating the pace drivers. Just give it a shot and let us know if it does the trick for you.
    Regards,
  • Thu, Jan 12 2006 10:22 AM In reply to
    • tikboy
    • Posts 236
    • Points 2,775
    Sorry man...NO LUCK!
    I tried:
    1. Clean Reinstal of ProTols
    2. Reinstall AvidXPro
    3.Installed Latest AvidXPro 5.2
    4. Updated PACE drivers
    Any other ideas?
  • Thu, Jan 12 2006 2:20 PM In reply to
    • dthompson
    • Avid Technology
    • Posts 66
    • Points 960
      Avid Employee
    Hmm...Ok, try this. Check your DAE folder and make sure you don't have any expired plug-ins hanging out there. It's possible you installed some demo plugins that have expired and when Avid or PT LE is trying to initialize these it's causing the hard crash. In the DAE folder you'll see two files for each plugin a ".dpm" and ".rsr"  just go ahead delete both for each plug-in.
    Hope this helps.
  • Wed, Jan 18 2006 2:23 AM In reply to
    • tikboy
    • Posts 236
    • Points 2,775
    Thanks.
    Im now in the DAE/plug-ins folder. How can I tell if it is expired? I don't remember installing any trials. Some of them have both ".dpm" and ".rsr".
  • Wed, Jan 18 2006 4:20 AM In reply to
    i had a similar issue and they recommended reinstalling the entire suite-i did a fresh install of windows as well
    http://www.avid.com/exchange/forums/39671/ShowPost.aspx
    dell m70/Pent. M 1.86/2gb ram/nvidia go1400 256mb/60gb 7200rpm internal system drive/60gb 7200rpm internal media storage drive/250gb usb2/1394 external... [view my complete system specs]
  • Wed, Jan 18 2006 7:28 AM In reply to
    • tikboy
    • Posts 236
    • Points 2,775
    Ok...i've finally decided to uninstall everything.
    Now, I am in the process of  reinstalling the Studio, and then upgrade Xpro to 5.2.
    I did the window's ADD/REMOVEprograms and unistalled evryone. I hope I did it right.
    I hope it will work as well.
    Thanks.
