Latest post Sun, Sep 28 2008 9:02 PM by Whitehorse. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Sep 18 2008 4:26 AM
    • Lowrider
    • Posts 95
    • Points 1,285
    SD Monitor to Color Correct HD Footage?
    Is it possible to use a SD broadcast monitor to color correct HD footage via firewire?  Meaning using a Canopus AV/DV type convertor to plug in the monitor via RCA outputs?  Or is another way possible?
    If not, what is the cheapest way to do a quick color pass on a feature film that is being submitted to Sundance prior to any online finishing?
    MC3, Dell T3400, Intel Core 2 Duo E8200 / 2.66 GHz, 2GB RAM, nVidia Quadro FX570, XP SP2 [view my complete system specs]
  • Thu, Sep 18 2008 4:51 AM In reply to
    Re: SD Monitor to Color Correct HD Footage?
    Anything is possible but what is acceptable to you? You are losing so much information.
    At least do it without going through DV compression. Mojo component out.
  • Thu, Sep 18 2008 7:10 AM In reply to
    • Lowrider
    • Posts 95
    • Points 1,285
    I don't have Mojo.  Is that the only decent way to get solid color correction with an SD monitor?  I need it to look very good.
    Is Mojo rentable?  If so, anyone know a place in L.A.?
    Are there options for using a HD computer monitor such as with the Matrox MXO that is made for Mac?
  • Thu, Sep 18 2008 10:20 PM In reply to
    • Lowrider
    • Posts 95
    • Points 1,285
    Anyone know?....In a bit of a bind here....
  • Thu, Sep 18 2008 10:28 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 14,246
    • Points 180,525
    L.A. Digital, Runway video, moviola and any number of rental houses in your area will rent Avid DNAs.
  • Thu, Sep 18 2008 10:29 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 14,246
    • Points 180,525
    Also, if you need it to look good, you better have scopes....
  • Fri, Sep 19 2008 12:43 AM In reply to
    • Lowrider
    • Posts 95
    • Points 1,285
    Thanks.  No luck at any of the places you mentioned renting a Mojo by itself (No at Moviola and not able to reach anyone yet at the other two) or a couple other places.
    Doesn't seem like anyone has the slightest interest in renting something like this by itself...
    Any Avid w/Mojo editors in L.A. who want to rent me their Mojo this weekend?
    And is there really going to be that much of a difference between using something like a Canopus converter and the Mojo for this?  It's simply to produce a very good color correct of a rough cut.  Isn't the color going to be the same whether it is HD or SD or whatever converted version of SD?  How much is lost in compression of contrast and what not?
  • Fri, Sep 19 2008 2:09 PM In reply to
    • cuervo
    • Joined on Fri, May 2 2008
    • Posts 169
    • Points 2,290
    Of all the things that won't be correct with an SD monitor, color is the biggest. Blacks are much deeper on an HD monitor. Chroma values are much more saturated, altho' the actual colors are not that much different. Noise is not so apparent on HD, so if you're doing noise reduction, you could overdo it with an SD monitor.
    Media Composer 3.05 on Win XP Pro SP3 - Intel x48, dual core quad 6600 - 4Gb RAM - PNY Quadro FX1700 - Echo Mona [view my complete system specs]
    Chalchihuitl Productions Music video, Digital Imaging JVC HD110--Sony EX1
  • Fri, Sep 19 2008 3:29 PM In reply to
    • ccarnazzo
    • San Francisco
    • Posts 17
    • Points 195
    have you thought about consolidating your sequence onto a portable drive and then taking it to a post house capable of HD color correction?  it's probably expensive, but I don't know if money is an issue.  But I bet a day spent at the studio would go a long way, even if you only came up with a few, solid fixes that you could apply globally.
    Avid Media Composer 3.0 Mojo SDI Microsoft Windows XP Service Pack 2 Duel Core 6600 @ 2.4GHz 2.00 GB RAM Sony XDCAM EX1 Sony Clip Browser 2.0 [view my complete system specs]
  • Sat, Sep 20 2008 7:10 PM In reply to
    • Lowrider
    • Posts 95
    • Points 1,285
    ccarnazzo:
    I like that....no, money is no issue at all....that's why I'm looking for solutions on an online forum...
  • Sun, Sep 28 2008 9:02 PM In reply to
    • Whitehorse
    • New York City
    • Posts 58
    • Points 740
     We use a Dell 24" 1200 x 1080i for our system monitor and it works quite well for color correcting, use the MC Color Correct toolset to tweak in your clips, then play it back full screen at full res to review. I know it's a pain not having the client monitor but this works quite well.
    Break a leg at Sundance
    MC 3.0.5, Windows XP SP3, Dell Precision T3400 2.66Ghz 4M E6750 CPU, WD 1TB Int HD, 4GB ECC Ram (Add3GB.exe set for 2.7GB), Nvidia Quadro FX3700, Highpoint... [view my complete system specs]
    Horse
