Latest post Mon, Sep 29 2008 1:42 AM by Michael16oz. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Sep 16 2008 5:35 PM
    • jdbrewer
    • Joined on Thu, Nov 2 2006
    • Salt Lake City, Utah
    • Posts 40
    • Points 630
    Red Online on Symphony
    I have received my first project shot on the Red.  The client has dropped off a drive full of .r3d files, and I'm trying to figure out my next steps.  My plan is to finnish on Symphony, although, I might move over to DS for the last touches.
    Assuming I stay on the Symphony platform, which Red apps do I need to use to ingest the .r3d files?  Is it as simple as exporting Quicktime Reference files from Red Cine, and importing into Symphony?
    I imagine this question has been answered several times.  If so, just point me in the right direction.
    -Jd
    Dual Boot Symphony/DS Nitris [view my complete system specs]
  • Tue, Sep 16 2008 6:01 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,837
    • Points 175,450
    Re: Red Online on Symphony
    If you search here for "Red", you will get a lot of threads discussing this.
    Here's one to start with.
  • Sun, Sep 21 2008 1:53 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 453
    • Points 5,565
    Here's my suggested RED/Avid Symphony finish workflow today.
    0. Get a Mac to process the QuickTime files. There isn't a RED QT Codec for Windows.
    1. Using REDrushed the first step is to select the folder with the all the original R3D
    files. Click the “Add Files” button and select the folder with the R3D
    files. It will also go through all the subfolders. All R3D files will appear
    in the main window.
    2. Next select the output folder for the QT reference files and the ALE
    file. File > Select Output folder.
    3. Select directory where ALE file should go. I suggest putting both the
    ALE and the resulting QT ref files into the same folder.
    4. Select Avid compatible audio. This creates 24bit audio as expected by
    Media Composer from the 32bit audio and No Resolution EXT (_H, _F, etc.)
    QT Wrappers > Options
    Select type of QT ref proxy you want created. For example, M is fine for
    offline work using DNxHD 36.
    5. Go to File Menu and select “export ALE”. Select the directory with the QT
    reference files.
    6. The folder will now contain the ALE file and all the QuickTime reference
    files for the selected R3D files. These are now ready for import into a Mac based Avid or saved as an Avid DNxHD QT file using QT Pro, MPEG Streamclip or the like. Import the ALE into a bin and Batch Import the QuickTime files.
    For a Media Composer/Symphony on-line a higher quality QT Reference can be
    created, either at first or after the fact, and batch imported into the Avid
    using a finishing DNxHD codec.
    -- Bob Russo Applications Editor at Avid Technology
  • Tue, Sep 23 2008 6:22 AM In reply to
    • jdbrewer
    • Posts 40
    • Points 630
    Bob,
    Thank you for the response.  It's difficult to tell on the Red site what the exact difference is between Red Alert and Red Cine.  -And RedRushes doesn't even show up on their list (it downloads with Red Alert).  -So your post was very helpful.
    Thanks.
  • Tue, Sep 23 2008 7:22 PM In reply to
    • jdbrewer
    • Posts 40
    • Points 630
    Okay, maybe I'm doing this wrong.
    1. I opened up REDrushes and added a .r3d file.  It shows up in the list.
    2. After setting the output folder (file>select output folder), and switching the audio option to Avid compatible (QT Wrappers>Options), I exported the ALE (file>export ALE).
    3. Result:  My output folder only contains the ALE.  But there are no QT reference files.
    Is REDrushes supposed to generate a QT reference?  Or does it just make ALEs?
    Thanks for the help again.
  • Tue, Sep 23 2008 8:55 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 453
    • Points 5,565
    Under QuickTime Wrappers make a selection on the type of QT Ref file you'd like to create.
  • Thu, Sep 25 2008 6:03 PM In reply to
    • jdbrewer
    • Posts 40
    • Points 630
    I selected Make Med/Qtr (M) under the QT Wrapper but nothing happens. I assume this is the part where it generates a list of reference files... but no files appear in my destination folder. Any ideas?
  • Thu, Sep 25 2008 8:15 PM In reply to
    some gold for you...
    Take all spaces out of all folder, dir and drive names..
    hope that helps
    Michael
  • Sat, Sep 27 2008 2:12 AM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 453
    • Points 5,565
    Do you have clips selected? Take a look at the info here:
    http://www.avid.com/red/
  • Mon, Sep 29 2008 1:42 AM In reply to
    Michael16oz:
    have you done this?
    to clarify redline and redrushes (at the moment) will not accept path names with spaces.
    M
