Latest post Thu, Sep 25 2008 11:51 PM by AkivaD. 18 replies.
Page 2 of 2 (19 items) < Previous 1 2
  • Sun, Sep 14 2008 6:03 AM In reply to
    • AkivaD
    • Joined on Tue, Apr 8 2008
    • Toronto
    • Posts 4
    • Points 40
    Re: Help with MC to After Effects, then back to MC
    Hi Larry, I did a copy and paste for my post and it inserted all that jibberish. how can i delete it? when i go under edit the jibberish part of the post is not there.
    MC 2.7, Windows XP pro SP2, Core 2 Duo E7200, 2 GB RAM, nVIDIA GeForce 7300 SE, Realtek HD. [view my complete system specs]
  • Sun, Sep 14 2008 6:14 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,992
    • Points 107,015
      Moderator: Meridien
     If it's not there when you go to edit your post, I guess you can't. Odd that it wouldn't display in the edit mode, though...
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Sun, Sep 14 2008 11:02 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 4,234
    • Points 48,665
    If you click on the HTML button at the right of the menu bar for the edit window you will see all the HTML code used in your post.  Remove any rubbish you see from the HTML window, not the edit window.  For example, this page in HTML should read as follows, since I haven't created any specific formatting.
    <p>If you click on the HTML button at the right of the menu bar for the edit window you will see all the HTML code used in your post.&nbsp Remove any rubbish you see from the HTML window, <strong>not</strong> the edit window.&nbsp For example, this page in HTML should read as follows, since I haven't created any specific formatting.</p>
    MC 4.0.3 - Asus P6T Deluxe V2 mobo - Intel i7 920 2.66GHz - nVidia Quadro 1700 - 12 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro firewire... [view my complete system specs]
  • Thu, Sep 25 2008 11:51 PM In reply to
    • AkivaD
    • Toronto
    • Posts 4
    • Points 40
    Thank you Jwrl.
