Latest post Wed, Sep 10 2008 1:09 AM by Adman. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Sep 9 2008 9:49 PM
    • Adman
    • Atlanta Georgia, USA
    • Posts 3,888
    • Points 43,150
    • Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Avid FX or Boris Red question...
    I am creating some vector imagery with the paint tool and I want an image to rotate when animated. The problem is that it is not rotating on the center of the object...I assume that Avid FX/Red calculates the center of rotation based on the first drawn node position or something.
    While I wish there was a way to change the center of origin/rotation such as in drawing and 3d animation programs, apparently there isn't... unless I'm missing something.
    Any tips or workarounds?
    Dell Precision 650, 3.06 Ghz, 2 SCSI drives, 600 GB LaCie D2, 3 GB Ram, Nvidia FX500 Suite 1. Avid Media Composer v3.0, Avid Studio Toolkit v 5.7, Pro... [view my complete system specs]
  • Tue, Sep 9 2008 10:20 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,142
    • Points 73,305
    Re: Avid FX or Boris Red question...
     Robert:
    Do you see a parameter for "Axis" ? Adjustments there will allow you to re-locate the center of rotation.
  • Tue, Sep 9 2008 10:58 PM In reply to
    • Adman
    • Posts 3,888
    • Points 43,150
    I don't believe so... do you have this parameter in Red specifically?
    Btw...I am also working on converting eps (Illustrator) files to splines but that is a different story.
  • Tue, Sep 9 2008 11:00 PM In reply to
    • Adman
    • Posts 3,888
    • Points 43,150
    There is only position, scale and rotate... no facility, afain, for moving the center of origin/rotation.
  • Tue, Sep 9 2008 11:09 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,142
    • Points 73,305
     I haven't worked with AvidFX or Red, but I've never encountered a 3D manipulation system that didn't have "axis" in it's control groups - FWIW, Boris F/X 7.0 3rd party plug-in does have it. Not in front of my Avid right now to confirm, but I believe it's in 3D Warp as well. Very strange.
  • Tue, Sep 9 2008 11:21 PM In reply to
    • Adman
    • Posts 3,888
    • Points 43,150
    You're sort of preaching to the choir on that one...
  • Tue, Sep 9 2008 11:54 PM In reply to
    • carlgmi
    • Western Australia
    • Posts 260
    • Points 3,265
    I dont think its there - I too have looked for it and cant find it.  One workaround I think I have used is to move the page in screen, then place that layer in a folder and pivot the folder.  The folder will rotate around its centre, not the centre of the page it contains.
    I think this extends to text centreing - how do you tell A-FX to start placing text from the top of the page instead of spreading from the centre out?
    Dual Xeon 3.06, Intel 7525GP2 server board, 2Gig ram, Leadtek Quadro1300, Intel Raid controller, 4xSCSI U320 Raid, IDE sys drive, 2 x Pyro64, Studio Compete... [view my complete system specs]
    That's not a dropout... it's an effect!
  • Wed, Sep 10 2008 12:05 AM In reply to
    • Adman
    • Posts 3,888
    • Points 43,150
    I went back and recreated the illustrator vectors...imported as eps files, converted to splines...rotated the splne track. I had to make sure the image was centered inside the spline track -- based on my desired center of rotation.
    It works different for vectors created with the paint tool within Avid FX apparently.
    Anyway...my workaround shoud work. Thanks for offering to help.
  • Wed, Sep 10 2008 1:09 AM In reply to
    • Adman
    • Posts 3,888
    • Points 43,150
    Thnx carlgmi...I must have been typing my post while you were posting yours. ;)
