Latest post Fri, Sep 12 2008 10:37 PM by AkivaD. 4 replies.
  • Tue, Sep 9 2008 7:32 PM
    • Duster
    • Joined on Fri, Sep 5 2008
    • Posts 5
    • Points 30
    No input signal
    Hi guys! I'm a brand new Avid MC user and I need some help.
    Actually, I'm not really a "user" but an IT tech in an university and I must give support to the "vid pros" using Avid MC and I'm kinda lost.
    So I apologize in advance for my (sort of...) lack of knowledge about video production/processing/edition.
    OK...first of all, even if this could has nothing to do with that, here's the setup:
    Computer
    • Intel S5000XVN Workstation board
    • 2x Quad Xeon E5420
    • 4 GB of RAM
    • Quadro FX 3700
    • 750 GB HDD (the edition is firewire external HDD based...Glyph GT050Q)
    • Firewire 400/800 PCIe 1x card (I guess Startech...)
    Softwares
    • Windows XP Pro SP3
    • Avid Media Composer 2.7 (v3.0 is in the mail...)
    • Quicktime 7.4.5.67
    • WMP 10
    • F-Secure 7.11
    • What else?!
    Camera
    • Panasonic DVCPro HD P2 AG-HVX200AP
    Both for you and me, I'll keep it simple.
    On this camera, there are a slide button to switch between 2 media; P2 card or mini-DV tape.
    And beside this switch, you can see a button to switch from "live" mode ("camera" red dot light On) to "recording/playback" (MCR/VCR green dot light On) mode.
    (Sorry for the blurry pic...cell phone, you know...)
    The problem is that I get "no input signal present" when I'm on Tape & Live mode at the same time.
    On P2 media, I have no single problem acquiring feed on both live or recording mode, even if there is no P2 card inside. Ok...with no card I see nothing on record mode but at least, I have a signal.
    On tape mode, MC has no problem with the signal as long as I'm on the "record" mode. Moreover, and it's the most weird part, IF I start MC with the camera on "record" mode AND then switch on "live" mode, it works!
    Is it clear enough?! I mean that MC says there's no input signal on "live" mode (mini-DV) as long as I didn't start it while the camera is on "record/playback" mode...
    So it's not a cable/firewire card/PC problem (kind of thing you'll usually look at when you have a "no signal" error message). Note that Windows itself has no problem with the camera on both media and both mode.
    So is it "normal"? Is it a camera bug or the problem is on the Media Composer side?!
    If it's a kind of bug, do you think the 3.0 version will solve it?
    I know what you're thinking...you wanna say that we just have to do the record/live switch trick and we'll be OK...true but I'm affraid that this bug (if it's a bug) hides more serious problems that will occur in the future. I imagine you know what I mean...
    So thanks for your help and...patience! And I really hope that all this make some sense to you. ;)
  • Wed, Sep 10 2008 4:46 AM In reply to
    • Duster
    • Posts 5
    • Points 30
    Re: No input signal
    Just a note to say that I'll order a Pyro Firewire card...just to make sure and be protected against futur problem.
    Is this model the best? The board has no PCI slot.
    PYRO1394 PCI Express
  • Wed, Sep 10 2008 6:18 PM In reply to
    • Duster
    • Posts 5
    • Points 30
    Re: No input signal
  • Fri, Sep 12 2008 3:59 PM In reply to
    • Duster
    • Posts 5
    • Points 30
    Re: No input signal
    I'd be glad to have your inputs guys...
  • Fri, Sep 12 2008 10:37 PM In reply to
    • AkivaD
    • Joined on Tue, Apr 8 2008
    • Toronto
    • Posts 4
    • Points 40
    Re: No input signal
    Once the deck is on go to deck configuration in the settings and it should find it.
    MC 2.7, Windows XP pro SP2, Core 2 Duo E7200, 2 GB RAM, nVIDIA GeForce 7300 SE, Realtek HD. [view my complete system specs]
