Latest post Mon, Nov 17 2008 11:52 PM by anamorphic. 11 replies.
Page 1 of 1 (12 items)
  • Sun, Sep 7 2008 6:14 PM
    • tere2008
    • Joined on Thu, Jun 19 2008
    • Posts 61
    • Points 905
    "bus error" in thread "main thread," at address oxo"
    I know this has been discussed here before, and I've read some of the threads regarding this issue,
    but I did not find a solution, if there is one.
    i get the above error message whenever I close my Avid MC program.
    Sometimes while i'm editing it will pop up and then when I click OK,
    Avid crashes.
    what is this, and what do i do about it?
    Has Avid found a solution for this error yet?
    thanks
    (1)-MAC: Mac OS 10.5 Leopard, Macbook Pro 2.16 GHZ,Intel Core 2 Duo, 2G memory, ati RadeonX1600 128mb,112gb boot drive, Graid firewire external drive 500gb... [view my complete system specs]
  • Sun, Sep 7 2008 6:18 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,815
    Re: "bus error" in thread "main thread," at address oxo"
    If you are not on MC 3.0,then yes, a lot of the bus errors were fixed in 3.0.
  • Sun, Sep 7 2008 6:44 PM In reply to
    • tere2008
    • Posts 61
    • Points 905
    thanks for the reply,
    yes, I am on MC 3.0.
    I don't quite understand.
  • Sun, Sep 7 2008 8:40 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,815
    Ok, disconnect your storage and see if the error happens when you close the app.
  • Mon, Sep 8 2008 5:39 PM In reply to
    • mvegas
    • Posts 1,186
    • Points 13,600
     The problem is caused by the installation of additional fonts on the Mac.  The workaround
      is to remove the caption.avx from the AVX 2 folder.  Removing this, however, will also disable
      subcap feature.  Avid Engineering has not determined which font or fonts are causing this as yet.
      You can try adding a folder, calling it disabled fonts and move 1/2 of your fonts into the disabled
      folder.
      HTH
  • Mon, Sep 8 2008 5:42 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,815
    Ah..genius.
  • Thu, Oct 9 2008 8:44 PM In reply to
    • mvegas
    • Posts 1,186
    • Points 13,600
     but wait there is more....   A search of the Mac fonts folder showed windows
    fonts. Once these were removed,  Composer would launch with the subcap avx
    active
  • Thu, Oct 9 2008 10:06 PM In reply to
    • cdumitrescu
    • Joined on Sun, Apr 13 2008
    • Bucharest, RO
    • Posts 16
    • Points 205
    For a while now I was running OSX 10.5.3 and MC 3.0.0 rock solid, no isses what so ever. Last week I've upgraded to 10.5.5 - 3.0.5 and I started getting bus errors and segmentation faults at exit and sometimes while editing..
    I dont have any fonts installed. Any way to get the stability of 10.5.3 - 3.0.0 back ?
    Cheers
    MC 3.0.5 software-only / Quad Core MacPro 4GB RAM / OSX 10.5.5 [view my complete system specs]
  • Thu, Oct 9 2008 11:11 PM In reply to
    Did you uninstall prior to upgrading?  Are you using SCSI drives?  If so, you'll need to upgrade the ATTO drivers.
    MC 3.0.5, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Fri, Oct 10 2008 2:53 PM In reply to
    • cdumitrescu
    • Bucharest, RO
    • Posts 16
    • Points 205
    I'm using only sata drives and external USB drives.
    I didn't uninstall first. Would it help if I uninstall - reinstall ? If so, what should I backup in order not to loose any settings ?
  • Fri, Oct 10 2008 3:55 PM In reply to
    You HAVE to uninstall first... it's a requirement.  Just back up your projects, though they should be fine anyway.  Run the uninstallers on any and all versions of Avid and then Re-Install.
  • Mon, Nov 17 2008 11:52 PM In reply to
    • anamorphic
    • BUDDHA JONES
    • Posts 60
    • Points 770
    What defines a "Windows" font?  Cuz I'm having the same problem.
    MacPro 2x3 GHz Dual-Core Intel Xeon / 6 Gig RAM / OS 10.5.5 [view my complete system specs]
