please ans me as soon as possible ?
I use avid HD for editing. client wanted to puts on beta tape and it has to play on right time like
SEGMENT TC IN TC OUT DURATION
Bars/tone 09:58:30:00 09:58:59:24 30sec
slate 09:59:00:00 09:59:29:24 30sec
clock 09:59:30:00 09:59:57:24 28sec
black 09:59:58:00 09:59:59:24 2sec
seg -1 10:00:00:00
they wants to start every thing in right code and the ply segment should play at 10:00:00:00. cliet as a beta tape without pre rec timcode tape they told me he can't bring the pre recorded tape. but he wants the thing . so i addjested the beta deck to 09:58:30:00 then i plyed several minutes blank to record the tc then i conected the deak to remote mode then in the digital cut i used remote mode but they needs to start on 10:00:00:00 so first i record the slate clock, black every thing then i stopped the deck then i was waiting the deck to come on 09:59:59:24 then i play the seqvence in project . but one one time it's work but not every time so . we are doing sercus in that recorder time if its fine ok but when it's wrong keep on sercusing every time so i wan't to know
Please help me to come out of this problems please.
Instead of recording bars, slate and clocks separately, why don't you just make a sequence with all that stuff at the beginning, and lay the whole thing to tape all at the same time using the Digital Cut tool?
good luck,Carl
yes i did that but it's not working correctly. i set the custom prerool also but its not geting. it's not starting it in 10:00:00:00 thats y. plese give me the suggestion to how can i burn only time code in to the tape. then it works properly. please. please mention all beta deck seting to perform burn tc in to the tape please.
First, feed your deck a black video signal, park on filler on the timeline. Set your time code to record run and preset, then set in the number 9:58:20:00. Record about 15 seconds of black on tape to 9:58:35:00. If it isn't already, modify your sequence time code to start at 9:58:30:00. Make sure everything in your timeline time code conforms to your requirements list. Go into deck preferences in your user settings and highlight "Allow assemble edits". Rewind the tape and launch your digital cut tool and set it for assemble edit and to start at sequence time. You're now good to go.
thank you very much. you are the people helping me to getout of my problem and giving me the hope i have to work in avid family soft using and building my editing knowledge also . In any other were i couldn't get. some people think that it's her secreats. But in here i got so many answer i am very happy i can't express my self how i am sencing. But i am very proved i got you and all . I am very thank full to AVID COMMUNITY . Thank you . Special thaks to Larry Rubin thank you
