Latest post Fri, Sep 12 2008 12:15 PM by JayEmm. 15 replies.
  • Sat, Sep 6 2008 4:40 AM
    • bw7001
    • Joined on Sat, Sep 6 2008
    • Posts 4
    • Points 70
    FX vs GE nVidia series
    I am looking at video cards and my understanding is this:  Editing high definition video relies more on processor and memory capabilities than it does dedicated graphics processing units.  Graphic rendering and texturing involved in 3-D (cad, etc.) programs are far more dependant on GPU(s).  And my question is, with Avid, is there a significant difference between the 8800 GT cards vs. the Quadro FX cards.  Specifically, I am looking at XFX GeForce 8800 ultra with 768 MB DDR3.  Shouldn't this card surpass the performance of the recommended Quadro 560 by miles?
  • Sat, Sep 6 2008 8:33 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,495
    • Points 40,410
    Re: FX vs GE nVidia series
    bw7001:
    It depends on the type of project that you're editing.  Avid uses the GPU in effects rendering.  The display card is very important.
    bw7001:
    To use the Avid supplied and approved display driver you require a Quadro card or at least a card that can be made to look like a Quadro card.  If you patch that card using Rivatuner you may be able to use it.  Until you try it you won't know.  So to quote Dirty Harry, "do you feel lucky?"  (Quote shortened in the interests of not starting fights).
  • Sat, Sep 6 2008 2:14 PM In reply to
    • DStone
    • Massachusetts
    • Posts 2,068
    • Points 27,460
    MC 3 is still highly dependent on OpenGL. The difference between the FX and Quadro cards is OpenGL support (physically the cards are generally identical except for the firmware identifying the card model; this causes a different set of drivers to get loaded when the card is installed). The Quadro drivers turn on all of the hardware based OpenGL support on the card. The FX drivers only enable partial OpenGL hardware support.
    As jwrl says, you can softmod a lot of NVidia (and ATI) desktop cards into their Workstation equivalents, in which case the workstation drivers get loaded. However, both NVidia and ATI have started locking the cards, preventing a softmod from working. I don't believe the 8800GT can be modded to a Quadro.
    Note that if you use a high-end FX card it may still have enough stuff turned on to allow for full usage of MC and BCC (e.g.full screen display, etc.), but you won't know until you try. And some things may perform more slowly until you've got a Quadro no matter what.
    Dave S.
  • Sat, Sep 6 2008 2:26 PM In reply to
    • tompearson
    • Joined on Thu, Mar 1 2007
    • Wayzata MN
    • Posts 476
    • Points 5,170
    so true i had an 6800 gt with my older avid 5.7 axp and rendering was a pain
    got a quadro fx3500 off ebay 200 bucks usd smooth sailing ever since
    selling my 6800 cheep
    asus mb p5wd2 dualcore 3 gig intel cpu's 4 gig crucial ram nvidia quadro fx 3500 1 tb wd sata 7200 raid 0 seagate 160 gig sata 7200 os drive mojo command... [view my complete system specs]
    Tom Pearson Director Hollywood-sounds.com
  • Sat, Sep 6 2008 6:59 PM In reply to
    • bw7001
    • Posts 4
    • Points 70
    Thanks for the speedy replies!
    What do you think of using 2 nvidia quadro fx4400's (instead of 1 really expensive card) with this motherboard...
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3523225&CatId=2050
    Any experience with SLI boards?
    Much appreciated!
    Ben
  • Sat, Sep 6 2008 7:28 PM In reply to
    tompearson:
    Surely you could have 'modded' that 6800GT into a Quadro FX4000 Surprise That's exactly what I'm planning on doing.
    So... that 6800GT... is that PCIe or AGP? How 'cheap' is 'cheap'???
    MSI Neo-2 Platinum Nforce3 Ultra (Bios Rev 1.0D) Athlon64 X2 4200+ (Overclocked to 2 x 2.4GHz) AMD Cool'N'Quiet CPU Throttling 2GB Corsair PC3200... [view my complete system specs]
  • Sat, Sep 6 2008 7:29 PM In reply to
    • DStone
    • Massachusetts
    • Posts 2,068
    • Points 27,460
    Hard to say. While a number of users who've posted indicate that they have SLI configurations, I've not seen any performance benchmarks posted.
    Dave S.
  • Sat, Sep 6 2008 10:24 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 951
    • Points 12,395
    DStone:
    ............The difference between the FX and Quadro cards is OpenGL support ................. The Quadro drivers turn on all of the hardware based OpenGL support on the card. The FX drivers only enable partial OpenGL hardware support.........................Note that if you use a high-end FX card it may still have enough stuff turned on to allow for full usage of MC and BCC (e.g.full screen display, etc.), but you won't know until you try. And some things may perform more slowly until you've got a Quadro no matter what.
     Dave, Either I am reading this too early on Sunday morning... or you wrote it too late on Saturday.
    Have you mixed up  FX / Quadro/ and GE.   I connect Quadro and FX as in "Quadro FX" and "GE" is the other group of NVidia cards.  I am not trying to be smart, but if you did make a mistake in the nomenclature it could be totally confusing for many readers of your otherwise useful post.
    Big Smile Regards,
    Douglas
    Avid Avid Media Composer 3/ Mojo DX,ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)4GB Kingston PC2-8500 DDR2 SDRAM,NVidia Quadro FX... [view my complete system specs]
    Douglas, Kumamoto, Japan - Avid Media Composer 3/ Mojo DX, (+Avid Liquid 7.2), http://www.gaijin-eyes.com
  • Sun, Sep 7 2008 4:07 PM In reply to
    • tompearson
    • Wayzata MN
    • Posts 476
    • Points 5,170
     as for the 6800  i was unaware of the soft modleing at the time  i was having trouble and the quadro was there and well the rest is history  and as we cannot sell on this forum e mail me and i will work somthing out for a fellow scot
  • Sun, Sep 7 2008 4:08 PM In reply to
    • tompearson
    • Wayzata MN
    • Posts 476
    • Points 5,170
     forgot agp
  • Sun, Sep 7 2008 11:29 PM In reply to
    tompearson:
    No probs, didn't want to breach the terms of use in here either. You've got mail Wink
  • Fri, Sep 12 2008 12:02 AM In reply to
    • JayEmm
    • Joined on Sun, Dec 16 2007
    • Posts 10
    • Points 120
    I have a computer with an 8800GTX "softmodded" to a Quadro 4600. So far, no complaints from AVID...
    ------ James Martin Film Student, Met Film School, Ealing Studios, London HP NW9440 w/ Xpress Pro 5.7.7 Sony HDR-FX1, HDR-HC1 and HC-3
  • Fri, Sep 12 2008 1:53 AM In reply to
    • DStone
    • Massachusetts
    • Posts 2,068
    • Points 27,460
    drbgaijin:
    I'm not sure what they call it in Japanese, but in English it's called "a mistake!" Embarrassed I meant GeForce when I wrote FX.
    Dave S.
  • Fri, Sep 12 2008 2:26 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 951
    • Points 12,395
    DStone:
    drbgaijin:
    Geeked  間違い  - You may have to change your browser "View" "encoding" to unicode or JIS to see that correctly. By the way it is read as "machigai"
    Where else, but the Avid Forum, can you learn about MC and Japanese at the same time? Yes
    Regards,
    Douglas
  • Fri, Sep 12 2008 9:21 AM In reply to
     SO... then how do I "softmod" my GeForce 9800M so MC can reconize it?  I hope I just have to look in the software config somewhere.  I really don't want to tear open a spankin' new laptop.
    WIN Vista Home Premium 64-bit (WILL upgrade soon), Intel(R) Core(TM)2 Duo Processor P8600 (2.4 GHz), 4GB DDR2 System Memory (2 Dimm), 512MB NVIDIA GeForce... [view my complete system specs]
