Latest post Fri, Sep 19 2008 1:25 PM by Larry Rubin. 14 replies.
Page 1 of 1 (15 items)
  • Fri, Sep 5 2008 6:18 PM
    • cristolin
    • Joined on Thu, Jul 31 2008
    • Posts 47
    • Points 830
    Question: title rendering?
     I created a title, edited into the timeline, and it won't show when I play the sequence; then I tried the "render at position" by right-clicking on the title clip and select from the menu, it worked. But at other times, it won't work, the "OK" button on that popup window grays out. Am I doing it right or I'm missing something here? I'm using MC3.0.
  • Fri, Sep 5 2008 6:21 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,815
    Re: Question: title rendering?
    You need to ensure that "render on the Fly" is checked under the CLIP menu.
  • Sat, Sep 6 2008 4:11 AM In reply to
    • cristolin
    • Posts 47
    • Points 830
     I did have that option checked (turned on), although it's actually under the "special" menu. What I found is that if I right click the title clip and go "render at position", it works; then if I move the position of the title clip, I may need to re-render the title clip, but some other times I cannot do the re-rendering because the option is just not available: the OK button on that "render at position" dialogue window is grayed out.
  • Thu, Sep 18 2008 9:34 PM In reply to
    • cristolin
    • Posts 47
    • Points 830
     I still haven't got this title playback issue solved. Any ideas? It's annoying that every time I move the title clip, I need to render it again. The render on-the-fly command under Special menu has been selected, but it doesn't seem to be working.
  • Thu, Sep 18 2008 9:38 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,815
    Check in your Render settings (Or maybe General, can't remember), Do you have render settings set to highest quality? If so, that will cause this. Make sure they get set to "Quality Set in Each Effect".
  • Thu, Sep 18 2008 9:41 PM In reply to
    • cristolin
    • Posts 47
    • Points 830
     Thanks for the reply. I checked the render setting, it was set to "quality set in each effect," so that's not the culprit here. I also tried the other two render settings but the problem persists.
  • Thu, Sep 18 2008 9:49 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,815
    Well, those are the only two options in the software that would cause this. After this, you need to try a new user setting. If that doesn't work, try a new project. If no Joy there, then you need to reinstall the software.
  • Thu, Sep 18 2008 9:51 PM In reply to
    • cristolin
    • Posts 47
    • Points 830
     what can go wrong in the user setting though?
  • Thu, Sep 18 2008 9:54 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,815
    Just about anything. It may not be the user settings but this is always a first troubleshooting step.
  • Thu, Sep 18 2008 10:37 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,173
    • Points 73,695
     Maybe I'm missing something here, but if you have clips on layers below the rendered title clip, moving that clip changes it's positional relationship with the lower layers and will always require a re-render. Can you elaborate?
  • Fri, Sep 19 2008 3:08 AM In reply to
    • cristolin
    • Posts 47
    • Points 830
     I'm not sure what you mean "clips on layers below the rendered title clip," what I have is a video clip on V1, and on V2 I have a title clip created with the basic title tool.
  • Fri, Sep 19 2008 12:44 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,173
    • Points 73,695
     Yes, so if you have a video clip on V1, a title superimposed over it on V2 and you render the title clip, the render includes the picture information directly under it on V1. Change the position of the title clip on V2 and you have changed what picture information will now be under the title clip and will require a re-render. But, if you have that simple a timeline construct, you really don't need to render the title clip. It will play in real time.
  • Fri, Sep 19 2008 1:18 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,815
    I believe that's the crux of the problem here Larry, it's not playing for him in real time.
  • Fri, Sep 19 2008 1:22 PM In reply to
    When the title isn't rendered and won't play back, what color is the dot on it in the timeline?
    MC 2.5.1 with Analog Mojo. HP xw8000, dual 3.0 Xeon, 3 Gig Ram, nVidia FX1100, ADS Pyro Firewire Card. [view my complete system specs]
  • Fri, Sep 19 2008 1:25 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,173
    • Points 73,695
     Cristolin:
    If the render settings are set for "quality set by each effect", the title clip should have a green dot, indicating real time playback.
