Latest post Tue, Nov 11 2008 8:20 AM by DIESELE. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Sep 5 2008 1:53 PM
    Betacam UW1400AP control problem
    I have Media composer3-Mojo SDi ,HP workstation and Betacam SP UW1400AP
    Betacam have RS232,25 pins controls.
    I have attached cable RS232-9pins to RS232-25 pins from computer to Betacam.
    In media composer,Deck configuration-add chanel,directs -Com1 and add deck Betacam Sony Uv1800P.
    But when I start Capture tool,software dosen't recognise Betacam at all.
    Anyone have experience with this problem and solution?
    People In Sony servise,say:
    "We can make you Cable but but you must tell us....Avid is using RS232 or RS422?"
    And I am confused.
    Thanks in advance
    Stefan
  • Fri, Sep 5 2008 3:12 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,173
    • Points 73,695
    Re: Betacam UW1400AP control problem
     For deck control in the capture tool and digital cut tool, Avid uses 9 Pin RS-422 connection. This means your computer must have a 9 Pin RS 422 connector.
  • Fri, Sep 5 2008 3:37 PM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 985
    • Points 11,655
    You can go to Addenda and purchase a box that will interface between the computer and the deck.  Most PC serial ports use RS-232 and the deck is ultimatly looking for RS-422.
    System #1 -Tyan i7525 MB, dual 3.2 Xeon, 4 GB Ram, Mojo, Quadro 3500, Pyro 64 FireWire, 6 TB Unity System #2 - Intel 7505VB2 MB, Dual 2.8 Xeon, 2 MB... [view my complete system specs]
  • Fri, Sep 5 2008 3:45 PM In reply to
    • daapap
    • Germany
    • Posts 115
    • Points 1,450
    vpcmike:
    this is not true, as the uvw 1200/1400 models have a 25 pin non-frame accurate rs232-interface.
  • Fri, Sep 5 2008 4:19 PM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 985
    • Points 11,655
    Thanks for pointing that out.  I was under the assumption that all of the Sony decks were looking for 422.
  • Fri, Sep 5 2008 5:31 PM In reply to
    • raspago
    • FL, USA
    • Posts 894
    • Points 11,020
    • Moderator: Spanish Language
    .- You need to convert from RS-232C to RS-422 and then "translate" from 422 back to 232 with a special addenda adapter.
    I'm gonna give you the product's links but now the addenda site is having problems.
    Custom made Intel core 2 duo 2.4 (overclocked to 3.0) Nvidia 8800GS, 3GB Ecc Ram, E-MU 1212M Sound card, Sata Drives, Analog Mojo. [view my complete system specs]
  • Sun, Sep 7 2008 12:22 AM In reply to
    • raspago
    • FL, USA
    • Posts 894
    • Points 11,020
    This is what you need:
    http://www.addenda-elect.com/product.htm
    "A combination of the RS-2/4 and RS-4/U allowing translation between computers (RS-232) and Sony UVW-1200/1400 decks. Intended for use with PC-based edit controllers such as Speed Razor, MCXpress, edit*, etc."
  • Sun, Sep 7 2008 12:23 AM In reply to
    • raspago
    • FL, USA
    • Posts 894
    • Points 11,020
    Any way, you won't get any edits using this since the 1200/1400 have no built in editing capabilities whatsoever.
    Just machine control, no insert, no assemble, no nothing.
    I think is not worthy, but that is just my opinion
  • Tue, Nov 11 2008 8:20 AM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Posts 110
    • Points 1,290
    Guys this is the case for any (or at least most) VTR control via Avid isnt it?  You have to have the serial converter box in the middle of the 9 pin wire between PC com port and deck remote control port.  Its the second thing I check for flashing lights when the VT and the Digi Cut tool fall out!
    I now need to source one myself for my SDi Mojo as it was a bit of an oversightGeeked
    D
    MC 3, XP SP2, Asus P5K-E Mobo, Dual Quad Core 2.4Ghz CPU (3.0 Ghz if I'm up against it!), 4Gb 800Mhz RAM Dual channel, 4 x 500Gb SATA Stripe O pairs, Quadro FX 1500 GFX, Soundblaster Audigy, Mojo SDi.  Sony PVM CRT.  Approved Avid HP 8240 Notebook. Original DIY PC: Shuttle SN85, AMD 3200, 1Gig Ram, Quadro 980, on board sound, on board firewire, 2 x SATA + WD ext HDD - could that be less 'compatible? Never hiccuped once! :-)
