Latest post Fri, Sep 5 2008 6:02 PM by Haze. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Sep 5 2008 12:18 PM
    • catwoman
    • Posts 105
    • Points 1,405
    title plug in
    I am looking for a plug in for MC to do the same as this really cool plug in:
    http://www.volumetrix.tv/
    Any idea? I have BCC, Sapphire and Avid FX but not sure how to use the ray effects so that the text actually appears with the light.
    Thanks.
    Hardware: Inted Dual Core 3 GHz Asus P5K Mobo 2GB DDR2-SDRAM (1066 MHz) NVIDIA Quadro FX 3500 SIIG firewire card Raptor 40GB SATA (system) Raptor... [view my complete system specs]
  • Fri, Sep 5 2008 6:02 PM In reply to
    • Haze
    • Posts 338
    • Points 4,570
    Re: title plug in
     You can get there using one of Sapphire's effects.  I think it's called edge rays - sorry not in front of the box right now.  Anyway, the trick to seeing the text is to lay the text on 2 tracks.  On the bottom track apply the "light rays" effect.  The top track is simply the text with a glow applied, it's needed because the effect on the bottom track destroys the legibility of the text.  Revealing the text can be as simple as animating the cropping or a more complicated approach is to use a hi contrast layer to control the masking.
