Hello all,
Perhaps you have experienced this issue. After a longer session of using Media Composer 3.0, when I exit (or quit) the application, I'll receive this message in an error dialog (screenshot attached):
'The instruction at "0x62305823" referenced memory at "0x00000000". The memory cannot be "read".
'Click on OK to terminate the program.'
That hexadecimal number changes based on the address in RAM being referenced.
Anyone know why this happens? As far as I can tell, this doesn't have any adverse effect on using it if I were to restart it after exiting.
Some proactive responses on my part to frequently made suggestions:
Please find my system specs in my signature. I've ran the "Install3GB.exe". I've searched the forum and only found one other reference to this error, but it was startup, not on exit.
My hope is that my RAM isn't faulty. I suppose running Memtest will give me some indication of that if that's true.
Any insight you can lend is appreciated.
Thank you,Isaquit0Hickie Smith Productionshttp://www.hickiesmith.com
No takers? Is this an unknown issue? Did I offend someone on the forum? Am I the only one experiencing this?
The only thing that I can suggest is some sort of display card or driver issue. I believe that AvidVideoMirror is used in FSP. Apart from that, I've nothing else. Sorry.
