Latest post Mon, Sep 8 2008 6:46 PM by Marianna. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Sep 4 2008 8:22 PM
    32khz in a 48khz project!
    I'm working on a massive project.  We have over 1000 hours of footage!  Just recently I had some interns digitize about 20 tapes that were donated by a contributing cameraman.  I didn't realize before they were digitized that he shot at 32khz instead of 48khz like the rest of the 980 tapes in the project.  In playback the tapes look fine, but of course the audio is jarbled.  I've tried just a simple "Change Sample Rate" but it doesn't do the trick.  Is there anyway of correcting the Sample Rate without redigitizing everything?
  • Thu, Sep 4 2008 8:44 PM In reply to
    • Avid Technology Inc.
    • Posts 787
    • Points 10,520
      Avid Employee
      Moderator: Broadcast Newsroom
    Re: 32khz in a 48khz project!
    shellsabell......
    It should work.  If you select the clips or sequence in the bin and then right click to change sample rates - it shoud work.   What version are you on and what cpu?
    marianna
    marianna_montague@avid.com
    813-493-6800
    AOL IM avidmarianna
  • Thu, Sep 4 2008 9:06 PM In reply to
    Oh sorry!  I am running Avid Xpress Pro v5.8.4 on a 1.25 GHz PowerPC G4 w. 1GB RAM.
    Thanks for the prompt reply!
  • Thu, Sep 4 2008 9:30 PM In reply to
    • Posts 787
    • Points 10,520
      Avid Employee
     I checked and Xpress Pro 5.8.x works the same way as I described above.
    Change sample rate is also under the clip menu ---  clip > Change Sample Rate.
    Report back and try both methods first before posting.
    813-493-6800
    AOL IM avidmarianna
  • Fri, Sep 5 2008 1:11 AM In reply to
    shellsabell:
    The trick is to select "delete original" when doing the sample rate change.
    Test it on an unimportant file initially as it takes a reasonably large leap in faith the first time you select that option.
  • Mon, Sep 8 2008 4:13 PM In reply to
    Yes, you are absolutely correct!  It did not work until I chose to "delete original media".  Also, I had to choose "Change Sample Rate" from the hamburger menu in the actual tape bin.  Choosing it from "Clip" in the main toolbar did not work.
    Thanks for all the help!
  • Mon, Sep 8 2008 6:46 PM In reply to
    • Posts 787
    • Points 10,520
      Avid Employee
    Andrew......... good save.  I forgot to tell shellsabell to do that one improtant little thing :)
    Sorry folks.... moving to fast.
    813-493-6800
    AOL IM avidmarianna
