Hi, im working with a Lanshare EX and when im going to work with a project then appears a message window: "this project or bin is locked, changes will not saved", the message appears with all the projects in all the workspaces.
i try to delete the files at the lanshare *.lck, *.mdb, *.pmr, shutdown the 7 newscutter clients and restart one by one. The problem appears again. Then i try to restart my ethernet switch, make a virus search in my LAN, delete the files again but the problem not disappear.
What can i do?
Luiselx.
It could be a bunch of things so wth this one I suggest you call in to AvidTech Support and let a tech assist you with figuring this out.
marianna_montague@avid.com
813-493-6800
AOL IM avidmarianna
Hi Marianna
The AvidTech Support find my problem. The Lanshare have a max number of files and directories if you exceed this number creates this problem. I delete a lot of directories and now, the lanshare works correctly.
The Lanshare can delete automatically the directories creates for himself at the Unity Attic folder? Because we have seven workspaces and in this folders theres a lot of directories.
Thanks.
