Latest post Wed, Sep 3 2008 12:34 AM by Ra-ey Saleh. 7 replies.
  • Tue, Sep 2 2008 8:56 PM
    • Rene Gomez
    • Joined on Sat, Jun 14 2008
    • Santiago, Chile.
    • Posts 58
    • Points 770
    Bring animate text from Avid FX to Media Composer
    I am made  some animated text  in Avid Fx. I exported it like QT Movie with  "Animation" compressor, but when I imported it to Media Composer i can see nothing,.... It just show  a black screen. After that, I tryed with other compression codec like : DNxHD, Avid 1:1, Avid 100, etc. With those compression is possible see the text, but not with Alpha Channel, It show a black background!!
    Any idea how to figure it out??
    Thanks !!
    MacBook Pro 2.4 GHz Intel Core 2 Duo, 2GB RAM, NVIDIA GeForces 8600M GT 256 MB, 200 GB HD. OS X Leopard 10.5.4 & Avid Media Composer 3.0.5 [view my complete system specs]
  • Tue, Sep 2 2008 9:45 PM In reply to
    Re: Bring animate text from Avid FX to Media Composer
    Rene Gomez:
    Does it come in as a Matte Key?  Did you select "Use Existing alpha"?  When you tried dropping it over some video, what do you see?
    Older versions of the DNxHD codecs did not support alphas.  The latest ones, which you can download from the Knowledge Base, do.
    MacPro Symphony Nitris DX (v3.0), MacPro MCA HD (v3.0), Mac Meridien (v12.1.2), Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Tue, Sep 2 2008 10:32 PM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 342
    • Points 4,095
    Rene Gomez:
    Thanks !!
    Hey Gomez,
    Sorry but I'm confused.  Why are you Exporting/Importing?  Why don't you just drop an AvidFX effect on your clip (from the normal Effects Palette) and then open it up from there?
    HP 8600 Symphony Nitris DX v3 Sapphire v2.07 Boris Continuum Complete v5.8 AvidFX (Boris Red) Heroglyth v2.6 Vitascene v1 Adrenaline (XP 8400)... [view my complete system specs]
    Ra-ey Q: "How many Editors does it take to change a lightbulb?" A: "Why do you want to change it?"
  • Tue, Sep 2 2008 10:38 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,173
    • Points 73,695
     Ray, I believe he is referring to this. Apparently, "send to" only works in SD.
  • Tue, Sep 2 2008 10:49 PM In reply to
    • Rene Gomez
    • Santiago, Chile.
    • Posts 58
    • Points 770
    Actually I didn't see nothing any  Matte Key.
    Just it show for default  Alpha: Staright
    What compression codec is the best for this king ok graphics??
  • Tue, Sep 2 2008 11:07 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,173
    • Points 73,695
     Your composition in FX needs to have an associated alpha channel. When you import into Avid, under the import options tab set as following: Aspect ratio = 601 Color levels = RGB   File Field Order = Lower (even) field first (assuming your location is Puerto Rico NTSC) alpha channel = use existing. You should wind up with a matte key graphic clip after import.
  • Tue, Sep 2 2008 11:09 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,173
    • Points 73,695
     Oh, and the best compression codec in this case would be same as source.
  • Wed, Sep 3 2008 12:34 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 342
    • Points 4,095
    Larry, now I get ya.  I've never used it this way.
