Latest post Thu, Sep 4 2008 4:31 PM by jknikman. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Sep 2 2008 1:16 PM
    audio tool
    i have mc adrenaline 2.1.6, hp wx8200, and today the audio tool is not responce.
    i cannot change the audio layers gain now. i have marks on layers 1-2 but they dont move the levels. at channels 3-4 i dont have the marks.  i check all the setting and compare it to similar room that work fine- and the setting are correct.
    the audio suite works good.
    the computer was format two weeks ago -and work fine till now.
    does anyone have idea what to do?
  • Tue, Sep 2 2008 1:26 PM In reply to
    • camoscato
    • Posts 4,650
    • Points 55,450
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: audio tool
    Look at the Timeline fast menu (the hamburger menu) under Audio Data.  Is there a check mark next to Auto Gain?  If not, put one there and see if that helps.
    good luck,
    Carl
  • Tue, Sep 2 2008 2:31 PM In reply to
    Re: audio tool
    i did it -doest help me.
    on the audio mixer you can see marks only on channels 1-2. channels 3-4 dont have marks at all.
    when you change the gain on 1-2 it change on the metters- but after you move the mouse -it back to what it was before - and dont change it for real.
  • Tue, Sep 2 2008 2:33 PM In reply to
    • camoscato
    • Posts 4,650
    • Points 55,450
      Moderator: Meridien
    Re: audio tool
    carmel adi:
    Are the audio monitors turned on for tracks 3 and 4 in the timeline?  (The little speaker icons next to the A3 and A4 buttons; are they on?)
    good luck,
    Carl
  • Tue, Sep 2 2008 2:58 PM In reply to
    Re: audio tool
    i built new project, new user, new seq 4 audio channels with -20db tone.
    when i stand on ch3-4 at the problematic computer- you can not see the marks at the audio mixer.
    when you stand on the same place at the other computer you can see them and change the level.
    all the settings are the same at both computers.
  • Tue, Sep 2 2008 3:08 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,018
    • Points 71,775
    Re: audio tool
     But you haven't answered Carl's question. On the problem computer, are the speaker monitor icons turned on for the tracks in question? If they are not, you will have no active adjusters for those channels on the mixer tool. Those speaker icons must be on.
  • Tue, Sep 2 2008 3:14 PM In reply to
    • Random Post
    • Toronto, canada
    • Posts 38
    • Points 490
    Re: audio tool
     Yes, the speaker icons must be visible, and the track CANNOT be locked. (pad lock icon to the left of the speaker icon)  I don't know how often I tried to adjust audio levels only to find out that teh track was locked.
    To lock/unlock a track, highlight the audio/video track in the timeline.  Got to the "Clip" pull down menu, at the bottom are lock/unlock.
    HTH
    Michel
    MC 3.0, Mojo SDI and Mojo analogue, approved Dell 670s config. 2Gb RAM, DVD, etc. D-Beta, BetacamSP, Sony DSR-45 DV/DVCAM, component'scope, monitors... [view my complete system specs]
  • Tue, Sep 2 2008 3:48 PM In reply to
    Re: audio tool
    the speaker icons are on, and the track ar enot lock - i try all the ways -i think it the bob. i will rty to switch bob between the computers.
  • Thu, Sep 4 2008 4:31 PM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,238
    • Points 36,795
    Re: audio tool
     I am not sure what you mean with marks? The wave form? (turn on sample plot in audio data, and if necessary put an IO point in the timeline depending on your timeline settings - maked wave form)
    also turn on clip gain and not only auto gain in audio data
    or can you not see enabled sliders in the mixe? ... if so turn on the tracks  by clicking on A3 and A4
    Dell Precision 670Xeon 3Ghz 3GB Memory1 x 250 Gb S [view my complete system specs]
