Latest post Thu, Sep 4 2008 7:17 AM by Baklap. 4 replies.
  • Tue, Sep 2 2008 12:04 AM
    • pagerussell
    • Joined on Mon, Apr 9 2007
    • Seattle
    • Posts 8
    • Points 130
    best exporting format for burning to dvds
    What is the highst quality exporting format? What is best if you intend to burn to dvds (and still have them work in average dvd players)?
    Asus p5k pro mobo, intel core 2 quad 2.83 penryn, 4gb ddr2 1066 ram, Windows xp 32 bit, Diamon Radeon 3650 1gb gpu. [view my complete system specs]
  • Tue, Sep 2 2008 12:38 AM In reply to
    Re: best exporting format for burning to dvds
    MPEG-2 is the DVD format.  So, you will need to get your sequence out as a MPEG-2.  I generally keep the bit rate between 4000 and 6000.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Wed, Sep 3 2008 4:25 PM In reply to
    • Klil
    • Joined on Mon, Jun 16 2008
    • Israel
    • Posts 8
    • Points 110
    Standard AXP does not support MPEG2 export as far as I know.
    Most of us export Quicktime reference (supposed to be a lossless format) and then use a different program to encode and burn DVD.
    Avid XP 5.6.3 on intel core 2 quad q6600 2.40G, 2G ram, win XP sp2, Gforce 8500 GT, 512, [view my complete system specs]
  • Thu, Sep 4 2008 12:05 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,495
    • Points 40,410
    Klil:
    For video there's no "supposed to be" about it.  Quicktime reference has that name because it consists of nothing more than a series of pointers to the original video media.  Because it's doing nothing to the actual material that it references, it must, by definition, be no more nor less lossy than the original media.
    Because QTref is designed to work with video only, for audio the situation is different.  Losses are possible.  Any audio component will be exported as a mixdown and re-encoded, and automatically dynamically linked to the QTref for playback.  If the audio codec used is lossy or at a different sample rate or bit depth to your original sound the end result can be degraded.
  • Thu, Sep 4 2008 7:17 AM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,625
    • Points 78,505
    pagerussell:
    Workflow
    Export QTref from Avid
    Import QTref into an Encoder and encode to MPEG 2
    Import MPEG 2 into a DVD authoring application and create a DVD
    Burn the DVD image/files and pray it plays Wink
    The above should give you more then enough pointers to search this site and the internet to get the picture complete.
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
