Latest post Fri, Sep 12 2008 6:00 PM by Phil Lowe. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Sep 1 2008 3:47 PM
    Anyone Running MC3 on a Pentium 4 3.0 Gig?
    I'm thinking its time to upgrade to MC3, but would rather not buy a whole new computer just yet. I know it is way under spec for MC3, but my current system runs AXP 5.8.4 pretty well.
    I've also read that MC3 takes better advantage of multi-threading, so it runs faster than AXP (the P4 is a multi-threaded processor).
    So has anyone tried this configuration?
    P.S. One other ?, can AXP and MC3 exist on the same computer? Since I'd be going outside of spec for MC3, I'd like to keep AXP as a back up.
    Thank much as always for all the help!
    P4 3.0. 2 Gig RAM, CAS 2.5. Intel 865PERL mobo. Two WD 7,200 IDE drives and two WD Raptor 10,000 SATA drives--no RAID. nVIDIA Quadro FX 1100. Two EIZO... [view my complete system specs]
  • Mon, Sep 1 2008 4:05 PM In reply to
    • dor
    • Israel
    • Posts 212
    • Points 2,685
    Re: Anyone Running MC3 on a Pentium 4 3.0 Gig?
     Hi
    Yes it can..
    Before upgrading I used P.4 3Ghz for few weeks and it worked well.
    It had some problems playing multi layers sequences in GREEN/GREEN mode, but beside that it worked OK.
    I don't think you can run both versions
    Dor
    MC 3.0.5 + MOJO SDI. Q9450+4GB RAM. 8800GT. XP PRO SP3 [view my complete system specs]
  • Mon, Sep 1 2008 7:11 PM In reply to
    • berga
    • Stockholm, Sweden, Europe
    • Posts 1,524
    • Points 18,340
    1. Yes, You can use it on a P4 3Ghz, or at lest on a P4 3.1Ghz. But I think You must pretend it as a temporal solution until You got he money (€1500?) for a new computer.
    2. I do not think they will because AXP is a x.8 generation and MC is a 3.0 generation.
    3. Do not be afraid of jump. All You effects will be the same, MC has even the templated 3D warp effects which was the only part of 3D warp in AXP. You can also map your keyboard as AXP.
    4. You can always uninstall MC and reinstall AXP.
    Jump, Jump!!
    HP xw4600, 3.2Mhz, 4Gb RAM, Mojo. 500GB SATA Bootdrive, 3x500GB internal raid-0 for video, Windows xp sp3, MC3.05 [view my complete system specs]
  • Fri, Sep 12 2008 11:49 AM In reply to
    I jumped!
    I should be getting the package in a few days. Thanks for all the advice and encouragement ;).
  • Fri, Sep 12 2008 5:13 PM In reply to
    • lunalobo75
    • Cuadra
    • Posts 24
    • Points 265
    Yep,
    it works smoothly on my machine.
    SAlud!
    MC 3.0, XP Professional SP3, P4 3.06 (yeah,P4) MSI 865PE Neo2-FIS2R, 4Gigs Ram, BFG AGP Geforce 7800 GS, 200 gig ATA 133 System drive, SATA 1Tb (Raid 0... [view my complete system specs]
  • Fri, Sep 12 2008 6:00 PM In reply to
    • Phil Lowe
    • SE Michigan
    • Posts 84
    • Points 1,195
    I'm running my MC3 on dual 2.8 Xeon processors with 2GB of RAM and Mojo and - besides noticing the long loading time of the software itself - have noticed no significant degradation in performance (I have always rendered all my effects anyway, so multi-layered real-time isn't an issue one way or another).
    I'm also running it on my new laptop: an HP Pavilion DV6000 Series with 3GB of RAM, Core 2 Duo 2.0 GHZ processor and Nvidia 8400 mobile graphics card with 256 GB of RAM, and Windowns Vista Home Premium, and it runs even better.
    Self-built system: Intel SE7505VB2 mobo 2 x 2.8 GHz Xeon processors, HT disabled. 2 GB RAM 1.25 TB media storage on two internal RAIDS ADS Pyro... [view my complete system specs]
    This space for rent.
