Latest post Sat, Aug 30 2008 5:18 PM by Job ter Burg. 7 replies.
  • Sat, Aug 30 2008 10:39 AM
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    best way to export to photo?
     What is the best export setting to expert an image in a (hdv)sequence to a sharp photo (for ex: jpeg or pict and should it be for ex. single field)?
    mac 0SX 10.5.2. dual boot 2.6 ghz intel core 2 duo 4 gb 667 mhz ddr2 sdram media composer 2.8 [view my complete system specs]
  • Sat, Aug 30 2008 1:12 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,828
    • Points 175,305
    Re: best way to export to photo?
    No, you don't want to use single field. Just export out as a high res JPEG and open the photo in photoshop and use its deinterlace filter if you want to blend the fields.
  • Sat, Aug 30 2008 1:14 PM In reply to
    • camoscato
    • Posts 4,683
    • Points 55,805
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    I took the 210 - Graphics & Mattes class a few years ago, and they taught us to export for still photos using square pixels, RGB color levels, and single field.  I wouldn't expect miracles, though.  Video is pretty low resolution compared to still photos.
    [EDIT] If you've got Photoshop, do it BLKDOG's way.
    good luck,
    Carl
  • Sat, Aug 30 2008 1:24 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,828
    • Points 175,305
    You don't want single field though Carl because the anti-aliasing won't be crisp. You need to do a blend of the fields for proper anti-aliasing.
  • Sat, Aug 30 2008 1:49 PM In reply to
    One great way to deinterlace would be to use Avid's FluidMotion. Deinterlace (part of) the source clip in Avid, then export both fields, not single, and then there's no need to deinterlace in Photoshop. Make sure to export as Square Pixels and at RGB  levels.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Sat, Aug 30 2008 1:58 PM In reply to
    • camoscato
    • Posts 4,683
    • Points 55,805
      Moderator: Meridien
    BLKDOG:
    I read it right out of the 210 book.  Any idea why the book would say single field?
  • Sat, Aug 30 2008 5:11 PM In reply to
    • sjon
    • netherlands
    • Posts 210
    • Points 2,780
    Thanks for all the comments.
    2 questions:
    1. I thought hdef video had a good resolution (?)
    2. What is Avid's FluidMotion?
  • Sat, Aug 30 2008 5:18 PM In reply to
    Yes, HiDef should definitely get you better pictures than standard def. However, Hi-Def is either 1280x720 or 1920x1080, while any decent still camera will easily give you 3500x2500 pixels.
    It's a vector based motion tool. In the TimeWarp effect, it allows for very smoothed slow motions. TimeWarp also gives you the option to choose interlaced source and progressive output. So if you take an interlaced video segment, and apply a 100% speed FluidMotion TimeWarp with Interlaced source and Progresssive destination, you end up with a deinterlaced clip. The deinterlacing is done by FluidMotion, which will use the info from both fields to create a single progressive frame.
