Latest post Sun, Aug 31 2008 1:36 AM by Rene Gomez. 9 replies.
Page 1 of 1 (10 items)
  • Fri, Aug 29 2008 5:24 PM
    • Rene Gomez
    • Joined on Sat, Jun 14 2008
    • Santiago, Chile.
    • Posts 58
    • Points 770
    Full Screen Playback
    HI,
    I have a Media Composer 2.7.4 software with this configuration:
    - Core 2 Duo 2.2
    - 2 GB RAM
    - MSI Video Nvidia GF 8400 GS (256 MB DDR2)
    The proeblem is than I can not play the sequence in FULL SCREEN  mode!!
    It said: "Check the video card compatibility in the Avid support web site" But I check the System Requirement and it said:
    NVidia Quadro FX 560 or higher
    • Note 1: Only Nvidia cards are supported
    • Note 2: Full Screen play feature requires a minimum of 128MB of graphics memory
    My video card is Nvidia and is 256MB
    If somebody knows something ABOUT IT, please let me know!!
    Thanks and Looking forward...
    MacBook Pro 2.4 GHz Intel Core 2 Duo, 2GB RAM, NVIDIA GeForces 8600M GT 256 MB, 200 GB HD. OS X Leopard 10.5.4 & Avid Media Composer 3.0.5 [view my complete system specs]
  • Fri, Aug 29 2008 5:31 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,828
    • Points 175,305
    Re: Full Screen Playback
     To what are your full screen playback settings set?
  • Fri, Aug 29 2008 6:20 PM In reply to
    • Solopost
    • New Jersey
    • Posts 1,060
    • Points 12,070
     The answer is in the details:
    "NVidia Quadro FX 560 or higher"
     Yes, you have an nVidia card - but your card is not classified as HIGHER than the QUADRO FX line of nVidia cards. That could be a cause of your woes. Although many folks have gotten other cards to work with Avid there is no guarantee.
    XW8200 2x3.2Ghz Xeon nVidia 3450 3Gb Ram Media Composer 3.0 w/Mojo 2Tb storage (mixed SCSI/SATA/1394)---------------Mac Pro 2xQuad-Core Intel 3Ghz 9Gb... [view my complete system specs]
    My Two Cents .02
    Kent Brockman
  • Fri, Aug 29 2008 7:30 PM In reply to
    • Rene Gomez
    • Santiago, Chile.
    • Posts 58
    • Points 770
    The settings is:
    Scaling: Project
    Full Screen (Check)
    Display Both Fields (Check)
    Flip on Vertical Sync (Check)
    Expand Luminance for Comp (UnCheck)
  • Fri, Aug 29 2008 9:43 PM In reply to
    • Rene Gomez
    • Santiago, Chile.
    • Posts 58
    • Points 770
    Yeah, I thought that!!
    I'm gonna try to sell it and buy the Nvidia Quadro FX 560 or higher!!
    Thanks for the reply.
  • Fri, Aug 29 2008 9:57 PM In reply to
    • Solopost
    • New Jersey
    • Posts 1,060
    • Points 12,070
    Again, before you run out and buy a new video board, do a search on the forums as some user have success with NON-approved boards... quite a few infact... so don't give up hope (or your cash) Big Smile
    My Two Cents .02
    Kent Brockman
  • Sat, Aug 30 2008 12:10 AM In reply to
    • Rene Gomez
    • Santiago, Chile.
    • Posts 58
    • Points 770
    Other people talk me than It's something about the resolution. Downing the resolution is possible to get full screen!!
    Somebody knows something about it??
    TKS.
  • Sat, Aug 30 2008 3:26 AM In reply to
    • Solopost
    • New Jersey
    • Posts 1,060
    • Points 12,070
     I have a screen setting of 1280x960. Either way, just try and see if anything works.
    My Two Cents .02
    Kent Brockman
  • Sun, Aug 31 2008 1:21 AM In reply to
    • Rene Gomez
    • Santiago, Chile.
    • Posts 58
    • Points 770
    Looking for a new configuration, I select "Change to a TV monitor" in Nvidia Panel. the video shut down and now I can't see nothing, but the computer is still ON. I restart it, but the screen  still  is black, no signal...!!!
    Anyone knows how to get the video signal again...I need to keep working, please!!
    Thank you!!
  • Sun, Aug 31 2008 1:36 AM In reply to
    • Rene Gomez
    • Santiago, Chile.
    • Posts 58
    • Points 770
    I fix it!!
    thank you anyway!!
    For luck I have a S-video plug in my monitor I connected it by this way, and I could see the Desktop and change again the settings...ufff
    Thank you and becareful with that
    Cheers.
