Latest post Mon, Sep 15 2008 7:46 AM by Sycophant. 77 replies.
Page 6 of 6 (78 items) « First ... < Previous 2 3 4 5 6
  • Fri, Sep 12 2008 6:22 PM In reply to
    • Avid 99
    • Dallas, Texas
    • Posts 392
    • Points 5,010
    Re: Don't make me go back to Final Cut Pro!!!
    I've been looking into using Color with Avid.  I've discovered a few options: Transcode your FCP Sequence QT to DNxHD or XML (Automatic Duck), recapture in FCP and use the FCP QT in Color, or do something crazy like export a QT Ref from Avid, bring to FCP, Add-Edit at every transition before bringing into Color. None of these are as simple as "Send to Color" from FCP.
    Is there another option?  Can Color import an AAF from Avid?
    MBP 17" - 1x2 2.33 - 3G RAM - 10.4.10 - 7.3.1 - MC 2.8 ***** MP (1/08) - 2x4 3GHz - 32G RAM - 10.5.4 - 7.4.5 - MC 3.0 [view my complete system specs]
  • Fri, Sep 12 2008 8:10 PM In reply to
    • lateral
    • UK
    • Posts 116
    • Points 1,415
    There is a very simple method to CC in Colour using your Avid Timeline.
    Export your full res seq from Avid as a QT. Best to use a supported codec.
    Export you seq as an EDL, cuts only.
    Import your EDL into colour using the Cutlist option and point to your QT.
    Though from testing, personally i'm not persuaded by Colour, especially the poor playback performance with HD.  The round trip nonsense to FCP is tiresome.
    Another method is to export your consolidated clips from Avid as QT's and an ALE.
    Use sebskys tools to convert the ALE to a batch list, add TC and then in FCP using an edl you can reconnect and then send to Color
    Supermicro X6DAE-G2, 2 x 2.8 Xeons, 2gb 2700 EEC Ram, 1 x IDE HD System drive, 1 x DVD-R, 6way G-Speed Array on UL4D, Slot 6 PCI-E. PCI-Express... [view my complete system specs]
    Eddtheditor
  • Mon, Sep 15 2008 7:46 AM In reply to
    • Sycophant
    • Auckland, New Zealand
    • Posts 781
    • Points 9,605
    I think I've posted this is a few places now, but as far as I can see, the best way to take an Avid edit into Color would be:
    1) Export QT and EDL from Avid.
    2) Import QT into FCP.
    3) Use 'EDL Mirror' to apply Avid EDL (cuts, dissolves and SMPTE wipes) to QT in FCP.
    4) Send to Color from FCP.
    This seems to be the most workable solution (although I haven't personally tried it) as Color can't render dissolves and things. Gives the most flexability.
    Color has some very good features, but still leaves a fair bit to be desired, in my opinion.
    All manner of fancy edity stuff [view my complete system specs]
    Dylan Reeve - Editor and Stuff
    My opinions are my own.
