Latest post Sun, Aug 31 2008 1:56 AM by BlueGirl Media. 4 replies.
  • Wed, Aug 27 2008 11:53 PM
    • marthaskol
    • Brooklyn, NY
    • Posts 249
    • Points 3,220
    color safe settings for PAL
    Can someone outline what I need to set the color safe limiter setting to for ultimate conversion from NTSC to PAL, composite, luminance, RGB, etc.  I already was rejected on one project after applying the effect, they said my luminance levels spiked to 103 in a few spots.  So I don't want to blow this one, any help would be appreciated.  I did a search and the only thing I really saw was RGB should be 16 and 235.  thanks again.
    Powermac G5 Quad 2.5 Ghz 4GB RAM NVIDIA Quadro FX 4500 Leopard. 10.5.3 Media Composer 3.0 QT 7.4.5 mojo SD Sony dsr20 Sony dsr11 Sony M10U [view my complete system specs]
    Martha
  • Thu, Aug 28 2008 7:23 AM In reply to
    • berga
    • Stockholm, Sweden, Europe
    • Posts 1,523
    • Points 18,325
    Re: color safe settings for PAL
    There is no universal standard for this in PAL. Different broadcasters can have sligthly different requierments.
    The Swedish national public service television use this standards.
    Maybe You can find something at EBU.
    But the most saftly bet is to ask they who will broadcast your project.
    You are welcome to return Your result of Your research. I think it would be nice if the PAL community can create a list of valid levels on the color safe limiter for PAL distribution.
    HP xw4600, 3.2Mhz, 4Gb RAM, Mojo. 500GB SATA Bootdrive, 3x500GB internal raid-0 for video, Windows xp sp3, MC3.05 [view my complete system specs]
  • Thu, Aug 28 2008 9:18 AM In reply to
    • Sycophant
    • Auckland, New Zealand
    • Posts 773
    • Points 9,525
    The limits you apply on your NTSC project aren't necessarily going to assure PAL legality, as there is a very real possability for colour gamut issues to arise in the conversion process - superblacks are a common issue.
    Most hardware standard converters (which is all I'd use for a broadcast conversion) will have the ability to legalise video as part of the process - just worry about making it NTSC legal and worry about the PAL issues as part of the standards conversion.
    All manner of fancy edity stuff [view my complete system specs]
    Dylan Reeve - Editor and Stuff
    My opinions are my own.
  • Sat, Aug 30 2008 9:28 PM In reply to
    • berga
    • Posts 1,523
    • Points 18,325
     Bump
  • Sun, Aug 31 2008 1:56 AM In reply to
    • BlueGirl Media
    • Joined on Tue, Apr 25 2006
    • Glasgow, Scotland (UK)
    • Posts 84
    • Points 1,170
    Check out the info myself and others suggested in this thread.
    http://community.avid.com/forums/p/33783/192274.aspx#192274
    Hope it helps
    Dual 2.7GHz G5 | 5GB RAM | SIIG Firewire 400 | MC 2.8.3 | Mojo SDI | 2x 23" ACD [view my complete system specs]
     If it ain't broke, don't touch it!
