Latest post Sun, Aug 31 2008 5:58 PM by Larry Rubin. 12 replies.
Page 1 of 1 (13 items)
  • Wed, Aug 27 2008 8:26 PM
    • Red Ochre
    • Joined on Fri, Jan 27 2006
    • San Francisco
    • Posts 218
    • Points 2,775
    resize alpha without resizing layer below
    When I resize an animation w/a matte key it resizes the video layer below as well. How can I isolate the resize to only effect the animation?
    MCA 2.7.2 (PC) and mojo MC 3.0 (mac) [view my complete system specs]
  • Wed, Aug 27 2008 8:36 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,828
    • Points 175,305
    Re: resize alpha without resizing layer below
     Is this a seperate Matte key with an independant Fill/alpha layer or is it a RT matte key with a nested fill/alpha?
    If it's the latter, just click the "Promote to 3D" button in the bottom-right hand corner of the effect editor and yo uwill have the parameters to move the key.
  • Wed, Aug 27 2008 11:07 PM In reply to
    • RUD ONE
    • Joined on Thu, Dec 14 2006
    • Milwaukee, WI
    • Posts 91
    • Points 1,080
    Are you adding a resize effect to your matte?
    MCA v2.7.1, 3GB Ram, HP XW8200 [view my complete system specs]
    Rud One - Milwaukee, WI
  • Wed, Aug 27 2008 11:10 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,132
    • Points 73,200
    RUD ONE:
     If you are, there is no need to. As BLKDOG said, just promote the matte effect to 3D and you'll have all the resizing, repositioning and rotation options you could want. And it will not effect the layer underneath.
  • Wed, Aug 27 2008 11:36 PM In reply to
    • Red Ochre
    • San Francisco
    • Posts 218
    • Points 2,775
    when I promote to 3D and reposition it still moves the image below. Is there some particular tool other than postion I should be using?
  • Wed, Aug 27 2008 11:52 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,828
    • Points 175,305
     In order to help you Red, you have to tell us exactly what type of Matte key you are using. IS this a three layer key (background, Fill, Alpha) or a two layer key (Background/RT Matte key)?
  • Wed, Aug 27 2008 11:55 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,132
    • Points 73,200
     Then, as BLKDOG pointed out, it's probably not a realtime matte key with it's own alpha channel. If not, you could export the fill layer of your graphic, take it into Photoshop and create an alpha channel, and then bring it back in as a RT matte.
  • Thu, Aug 28 2008 5:06 PM In reply to
    • Red Ochre
    • San Francisco
    • Posts 218
    • Points 2,775
    I'm getting the message RT matte key and RGB are limited to two layers when I step in so it must be a RT matte. when I promote to 3d and reposition the alpha and V1 move but not the animation!
  • Thu, Aug 28 2008 5:17 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,132
    • Points 73,200
     Well, that's really strange, because as I write this, I have an RT matte key graphic promoted to 3D and both the fill and the alpha move without affecting the background on V1. You might want to try a new user profile and see if the problem persists. If it does, rebuild the site settings files, they may have become corrupted.
  • Thu, Aug 28 2008 5:43 PM In reply to
    • Red Ochre
    • San Francisco
    • Posts 218
    • Points 2,775
    OK. digging deeper it looks like alpha was imported wrong so the other guy on this project swaped sources in the matte key. For some reason this effects the position parameter. I'll just reimport. Thanks all.
  • Thu, Aug 28 2008 5:50 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,132
    • Points 73,200
     Good. I knew it had to be some kind of operational error, but didn't want to make any "accusations".   Lord knows, we have enough of that going on in the political world, we don't need it here! Wink
  • Sun, Aug 31 2008 5:48 PM In reply to
    • Leo153
    • Joined on Sun, Jul 1 2007
    • Lee, MA
    • Posts 87
    • Points 1,035
     Larry & group,
    I use a lot of .PNG graphics I make in Photoshop, are those alpha's RT? I've haven't tried promoting them as suggested, but I have the same problem Red did when I try to move them. As mattes they look great, what import settings should a .PNG file be set for?
    Thanks...
    AMC 3.0, Nvidia 169.47, QT 7.4.5 [view my complete system specs]
    Leo Mahoney Mallard Video Lee, MA www.mallardvideo.com. HP 8400 2.66 2Xcore, Media Composer 3.0, Windows XP SP2 2 ,Gig RAM,Stage Tools- MovingPictures, 3 prong- WaveScope & SpeedRamP, Trapcode- Shine2, AVX, BCC, G-SATA 0 RAID, GTech's FW400, NVidia FX-1500 ver. 169.47, QT 7.4.5, Mojo SD, 24" and 22" HP monitors. Member: Boston Avid Users Group (BAVUG).
  • Sun, Aug 31 2008 5:58 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,132
    • Points 73,200
     Leo:
    Yes, alpha channels made in photoshop are RT mattes when imported into Avid. The import options should be aspect ratio = 601, color levels = RGB, File field order = non-interlaced, and "invert" for alpha channel. If after importing, the matte key clip looks totally black, try "use existing" for the alpha option. But it definitely comes into the Avid as an RT matte and you should be able to promote it and move around without affecting lower layers. I do it all the time.
